Originally Posted by bbbymac
I hope this is the same for a 2015 Wildwood. The D seal on mine went and it looks like they glued it to the wiper piece. I hope I can get them apart or I will have to replace both pieces. You tube says it is about a 3 hour job. The hardest part being removal of old adhesive.
On your Wildwood you should have an EK flap seal, and a "D" seal like below.
The "D" seal slides over the flapper seal after you attach the flap. There should be a screw at each end of the D seal to hold it in place.
Also, they should be black instead of white.
