10-03-2020, 05:45 PM
Sap removal
I need help. I have been scouring the net looking for the best process to remove tree sap from the front of my travel trailer. The best I have found is isopropyl alcohol but I worry it will ruin the finish. As I spot tested and it left a dull mark so I stopped. Is there a better way or can I wax and buff to bring the shine back?
Thanks, Devon
10-04-2020, 12:20 AM
Thanks, Devon
Both Mayonaise and Peanut Butter are supposed to be great for removing tree sap.
Apply, let sit a while to soften, then go after it with a soft cloth. Rinse, repeat, as necessary.
Neither should harm finish or shine but may remove any wax you previously applied.
10-19-2020, 05:45 PM
I’ve always used motor oil to get pine sap off my hands. Probably why mayo works. Maybe try out of the way spot w/cooking oil or mayo. Worth a try.
JB
10-20-2020, 09:27 AM
Retired Panpsychist
I've successfully used Rapid Remover for pine sap on both my TT and TV. I am very careful about its application on the TT and avoid using it on an area where the edges of the TT's decals are applied.
As with all chemical solutions, try the product out on an inconspicuous area first. My TT is gel-coated fiberglass.
Here's what I do. Use the heaviest (most absorbent) paper towel you can find and cut it into 1" or 1.5" squares depending on the size of the sap marks. Saturate the squares with the Rapid Remover but not so much that they drip. Apply the squares to each sap mark and let them sit on the mark in the shade. Wait about 10-minutes and (one at a time) remove each square and immediately try to wipe-off the residue. If any remains, reapply a new saturated square and move on. Once all sap marks are gone, clean the area and apply a fresh coat of wax/sealant.
As always, YMMV.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
10-24-2020, 02:34 PM
I have excellent luck using olive or vegetable oil to remove pine sap from my dog's fur, should also work great on the camper. I'd try a small spot and see what it does to the finish first.
-Jamie
2020 GeoPro 19FBS
2021 Ram 1500
10-24-2020, 02:35 PM
Turpentine will dissolve pine sap. Wear gloves- it's smelly. Been there done that on my truck more than once.
Peace!
Dan & Rita D
10-25-2020, 01:31 PM
Just as confused as you
As it should. Organic turpentine is made from distillation of live tree sap, mainly pine.
Richard & Jill
06-08-2021, 09:30 PM
Orange mechanic soap or mayonnaise.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
06-08-2021, 09:56 PM
Try Purell. Has just enough alcohol in it to remove the sap but doesn’t evaporate as quickly because it’s a gel. Since it’s made for hands it’s not as harsh.
I would try it on one spot first, and after you get the sap off wipe it with a wet rag. Try not to do it in full sun.
I used this method to get sap off my black truck did it in full sun and nothing bad happened.
2020 Salem Hemisphere Hyper-Lyte 25RBHL
2022 Ford F150 SuperCrew 3.5 Ecoboost MaxTow
07-23-2021, 02:12 PM
The only way I've been able to remove tree sap is with plain cold tap water and a wash mitt. No soap, just cold tap water.
07-23-2021, 03:19 PM
Charcoal starting fluid - something most have onboard the RV anyway
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax Curt Q20
