I would think that it would be pretty easy to replace the sliding door with a set of french doors. Double check the height to make sure it's the standard 6-8 height door. You can order custom sized doors, but they get pretty expensive if you have to.
The jamb with will probably be wider than the current door, but you can shim the wall to fill the space and get some matching trim to cover the shims.
Gotta go campin!
