Old 01-18-2019, 09:59 AM   #121
Storage of sway control bars
I just put them in the bed of my truck.
firemedicmark is offline   Reply With Quote
Old 01-19-2019, 10:51 PM   #122
Copy cat
After see what someone else did, I made a box that holds all of my WDH pieces for easy access when I do need them. No more grease either.
ID:	194986   Click image for larger version
ID:	194987   Click image for larger version
Bagger is offline   Reply With Quote
Old 01-19-2019, 11:02 PM   #123
I'm Lost
wabakami's Avatar
Very nice job, well done.
Geoff
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2013 F150 Screw, 6.2L gasser, HDPP, LT tyres, Firestone Air Bags, 250L aux tank.
2013 Rockwood Signature 8310SS
wabakami is offline   Reply With Quote
Old 02-18-2019, 05:17 PM   #124
cincia's Avatar
wdh bars
I have a set up like rockfordroo. Took a piece of 3"? PVC, painted it black and strapped it on the tongue right in front of the trailer. Since our rock guard on the tt is black most people don't even see it there. The bars slide in (one on each side), it's almost the same height as the bars are when set up so very little lifting, just swing around and slide bar into PVC, put on end cap. Out of sight, out of the weather, not in the dirt or taking up space in my pass thru. they always go there so we know exactly where they are. easy peasy.
Lisa and my furry kids - Cesare, Cincia, Dante, Capucine, and Scout
Chevy Express 3500 van
Palomino Solaire 251RBSS
Wherever you go, go with all your heart.
cincia is offline   Reply With Quote
Old 02-18-2019, 06:38 PM   #125
Take it easy,but take it
Thanks--for now i will use newspaper bags--until spring comes that will have to do !!
Nickrenfro is offline   Reply With Quote
Old 02-18-2019, 06:53 PM   #126
I bought a 36" tray to catch water from a long flower box. My bars fit nicely in it and keeps the grease off of items in the storage compartment.
Rmstack is offline   Reply With Quote
Old 02-18-2019, 11:30 PM   #127
Retired Old Fart
dward51's Avatar
I like this idea. I'm going to make one for my front compartment which does not have a factory slide tray. Krushad made a two level slideout tray. Bottom is the perfect place for the bars etc...
http://www.forestriverforums.com/for...ay-177944.html
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 03-30-2019, 06:38 AM   #128
IchLiebeBier's Avatar
@profchuck
I saw your setup in Trailerlife magazine and remembered your post. I'm curious, and couldn't figure it out from your pictures. What did you do to connect the open ends of the u bolts so they couldn't be removed from the frame? Just a piece of flat metal bolted over them? Or is the pipe strap long enough to connect to both sides?
Thanks.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is online now   Reply With Quote
Old 03-30-2019, 04:59 PM   #129
Originally Posted by IchLiebeBier View Post
@profchuck
Thanks.
What I used is the flat piece of metal that comes with the U-bolt. I put that on first and then on the outside side of the U-bolt I added a washer and the pipe strap and another lock washer and the nut. The picture is a shot head-on to the trailer frame so you can see the metal piece and the strap. I tightened the bolts so the metal bent just a bit so the pipe straps wouldn't move. Hope this helps.
ProfChuck is offline   Reply With Quote
Old 03-30-2019, 05:04 PM   #130
By the way, the two hex nuts on the frame that the U-bolt is going between are leftovers from an old sway control I removed and have nothing at all to do with the set-up. They are just keeping those holes in the frame filled so water doesn't get in. The Equalizer hitch didn't need them when it was installed.
Old 03-31-2019, 09:16 AM   #131
Thanks. I'm looking to do this, just needed to know what all I need to buy beforehand.
2018 Ram 2500 CTD
Old 03-31-2019, 09:33 AM   #132
Originally Posted by NJKris View Post
I really can't imagine somebody bothering to steal a WDH bar. That would be so odd.
Brother-in-law lost his. Laying across A-frame. Also lost his power cord and so did 12 other units that night. Scrappers went around cutting the cords off the Trailers and any bars laying around. They caught them the next day...as the idiots were STAYING IN THE CAMPGROUND.
TheWolfPaq82 is offline   Reply With Quote
Old 08-15-2019, 09:54 AM   #133
Mizterusa's Avatar
I jus leave mine on my truck..... Why move anything while it's already stored? Makes for a nice step too.
Mizterusa is offline   Reply With Quote
Old 08-20-2019, 07:11 AM   #134
Night Stone's Avatar
I know this is a late response but, I use Ziploc baggies for the greasy part of the bars and put into a underbed bin that fits through the storage opening. The baggies hard comes off due to the grease, still using the original baggies since 2013. But I like the idea of the old rifle case as mentioned above.
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015-18, 0 Days so far
Days camped in 2019, (8)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 08-24-2019, 11:35 AM   #135
fenton04's Avatar
Originally Posted by TitanMike View Post
When I'm done dumping my tanks I pull my blue nitrile gloves off with them ending up inside out. I have a small cardboard box in my storage compartment that I drop them in. When I unhitch I merely take a couple of those gloves and slip them over the greasy ends of the bars and stick them in the pass through storage. Also put a glove over the trailer ball. Any contamination is on the inside of the glove and my bars don't seem to care.
When hooking up I then just pull them off and throw away. Double duty and they do a good job of keeping the black grease off everything.
Exactly what I do! Double duty for the nitrile gloves. Plus more room at the land fill!
Tow vehicle 2015 Nissan Titan PRO 4X
Coachman 2019 Apex 249 RBS.
Where to next?
Tony, and Vicky
fenton04 is offline   Reply With Quote
Old 08-24-2019, 12:17 PM   #136
I haven't read thru all 140 some post. I keep the bars and the head and ball right on the trailer.
storage, sway
