10-27-2018, 08:03 PM
#61
Storing Equalizer Bars
Thanks to rockfordroo for the idea of using 2 inch PVC pipes to store the bar. I went down to the hardware store and bought two, 3 foot sections of ABS 2 inch pipe. I also bought 4 end caps and permanently attached one end cap to each 3 foot section of ABS pipe, put the bars in each pipe and just put on the other 2 caps. I just store the two pipes in the front storage compartment of the travel trailer, and that totally keeps the compartment clean. Thanks again rockfordroo for your idea that I modified.
10-27-2018, 08:34 PM
#62
And I just have a roll of paper towels and a plastic bag handy. I wipe the grease off and store in the front storage compartment of the travel trailer.
2018 Forest River Flagstaff E-PRO 19FBS
2107 Toyota Highlander
10-27-2018, 11:47 PM
#63
You're welcome. Glad it gave you an idea that works for you.
2011 Traverse LT, 3.6L, FWD
10-28-2018, 08:32 AM
#64
I found a storage spot on my Mini Lite - it's under the battery tray. To secure them, you could put a bicycle lock through the holes of the WDH bars.
-Rich
10-28-2018, 04:02 PM
#65
Crown royal purple bag. I seem to have a lot of these laying around.
2017 Rockwood Minilite 2109S
2017 GMC 2500HD gasser
10-28-2018, 06:22 PM
#66
Trailer Park Supervisor
Markval, see post #45. You have a kindred spirit!
Yes, I drink the water!
10-29-2018, 06:09 PM
#67
Take it easy,but take it
Perfect !! Why didnt i think of something so simple !!! Thanks
10-29-2018, 06:10 PM
#68
Storage of rods
I put mine in a plastic bag re new every trip to grocery shop
10-29-2018, 06:13 PM
#69
We wipe them off before putting the them away. Put on fresh coat when travel again
10-29-2018, 06:29 PM
#70
Great idea, but do you then put the sewer hose in the bumper? Wouldn't the sewer hose then be greasy.
I just bought a tray for a long flower container that the bars fir into perfectly. I can store them under the camper. But I shall try your method. A plastic bag over the greasy parts would work.
10-29-2018, 06:49 PM
#71
Originally Posted by rockypal
Check the manual for your hitch - my hitch instructions explicitly state not to lubricate the bars at the sliding point of contact with the L-brackets attached to the trailer frame (e2 hitch system). --Ray
Makes perfect sense, since that sliding point needs the friction for the sway control. If it's lubed, there's less friction and this less sway control.
10-29-2018, 06:59 PM
#72
Sway control bars
True, you are not supposed to lube the L bracket contact areas. That is your sway control and they have brake material on them and the L bracket for friction.
Along those lines, does anyone know if you have to replace those bars after the material wears down?
10-29-2018, 07:25 PM
#73
storage of sway control bars
I use a heavy duty plastic bag with a rubber band around the bars to keep it in place. I store them in the front compartment. I made a stand for the hitch that is locked to a chain around a trailer wheel.
Dave & Elaine
Brookfield, WI
2021 Rockwood, 2509s, pulled by a 2020 Ford F150 XLT, Super Cab, 3.5L Eco Boost, with 3.55 axle. Electric 10-speed auto trans w/tow mod. Heavy Duty Tow package & integrated trailer brake, 11,700 lb. tow capacity, payload is 1916 lbs. and 145” wheel base. Equalizer 4 point W/D hitch.
10-29-2018, 07:36 PM
#74
Below the storage box you can see the end of a torsion bar. I installed a piece of 3" aluminum square tubing on each side of the trailer frame. They angle down slightly and are welded together under the center of the trailer. This helps keep the torsion bars in the tubing during storage or when moving around at home. This has definitely solved the problem of "what to do with the greasy torsion bars" at a campsite or at home.
10-29-2018, 07:41 PM
#75
The wife holds a walmart sack and I slip the greased end of the bar in the sack to be explicit. Then into the front compartment they go.
10-29-2018, 07:56 PM
#76
Storage bag
I bought a storage bag at camping world, you can also find them on Amazon
10-29-2018, 07:58 PM
#77
Purchased a PVC post at Lowes. Cut the PVC post the length of the bars. Placed end caps on the post. Mounted the post to the hitch just in front of the battery boxes. Keeps the bars and pins out of the way for storage. Also keep a set of gloves and a rag with the bars. Easy and inexpensive.
10-29-2018, 08:00 PM
#78
I'm surprised nobody has commented on this. Blue Ox WDH bars never get greasy so I don't have this problem.
10-29-2018, 08:48 PM
#79
I’m new to the forum, so looking for some clarification. I was once told the friction made at the point of contact between the bar and the bracket in the tongue for my style of weight distribution hitch is how the system prevents sway. Not sure if you have the same system but would be interested in others thoughts there. Thanks.
10-29-2018, 08:54 PM
#80
Equalizer Bars need no grease
Others should just read what Equalizer recommends, and what other people have written. The equalizer bars should not be greased, and should be clean. Look at the diagram that someone submitted that shows the only place you grease is above and below the receiver for the equalizer bars. Can’t we just put this to rest?
