Originally Posted by TomatoMan
when home in the past I am plugged into shore power and run AC at 88 degrees.
You didn't mention what type of rig you have and that could affect the advice you get.
Do you have anyone who can check on the rig when you're gone? Doing what you've done in the past will help protect the inside of the rig if someone can check on it. If you can erect some type of canopy (canvas would work), that will help.
Otherwise, if you've got a fan cover like this, leave the fan cracked open to let some heat out and don't worry about it. Usually DampRid is recommended, but that might not be necessary in the desert.
https://www.amazon.com/Camco-40433-R...7267305&sr=8-5
Edit.... I see you have an 2021 Isata. Personally, I'd see if you can find storage with roof cover, or a completely enclosed storage and find a way to cover the cost.
