Old 02-17-2017, 05:37 PM   #41
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by robbdrell View Post
Just got a new a new GMC and haven't towed my 30' TT yet. So with my DuraMax when do I use the exhaust brake? With the tow/haul mode? Please don't tell me to read the manual and push the button. LOL
Anytime I am towing the TT or boat (6,000 lbs) I activate Tow mode and the Exhaust Brake....a slight pressure on the brakes and the truck takes over for a smooth stop! Definitely a brake saver. If you use it once you will be sold, its a great feature!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 02-17-2017, 05:38 PM   #42
mike.t's Avatar
See post #38
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
2012 Dodge Challenger
I was never taught not to like you, you did that!
mike.t is offline   Reply With Quote
Old 02-17-2017, 05:43 PM   #43
Tow Haul?
There's a reason Tow/Haul is on the truck. Use it.
There's always some "expert" who will tell you you don't "need" something that was designed to use,. I guess they know better than the design engineers. I mean, check the threads on any forum about wether you "need" a weight equalizing hitch. For every person who says "Get one, use it, add to your safety factor.", there is someone who says "Why I've driven a billion miles, towing a big rig trailer with my volkswagon and NEVER had a bit of trouble. Even did the Kessel run in 12 parsecs!".
There's a reason it on there. Use it.
hankpac is offline   Reply With Quote
Old 02-17-2017, 06:15 PM   #44
genehorn's Avatar
Originally Posted by TexasBob View Post
I use the tow/haul anytime I'm pulling my trailer. I even us the cruise control when its nice and flat.
X3
Gene
2016 Wildcat 28SGX
2016 GMC HD Duramax
genehorn is offline   Reply With Quote
Old 02-17-2017, 06:51 PM   #45
Originally Posted by Slow but Steady View Post
I have an RV trailer that weights about 6200 dry, and about 7000 lbs loaded. When I am driving on normal roads (not up and down grades/hills/mountains) is it best to still keep the automatic trans in the "towing mode" (by pushing the button in at end of the shifter)? I have hear mixed opinions, and of course I don't tow over 55 mph.
Thanks so much.
Tow/Haul, anytime, every time, you tow or haul 'anything' in any terrain. Put it in D, set cruise control to the speed you want to travel. Saves your transmission from over heating, over stressing.
EdnKat is offline   Reply With Quote
Old 02-17-2017, 07:02 PM   #46
Prime Member
Originally Posted by DouglasReid View Post
You did not mention anything about your truck. IF you have a Duramax Diesel engine with the Allison transmission you must have it in tow/haul mode in order to have the benefit of transmission braking when slowing down.
I disagree. I have a Duramax with the Allison tranny. I use the exhaust brake all the time when not towing.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 02-17-2017, 08:17 PM   #47
"When all else fails, read the instructions!" LOL
2011 Traverse LT, 3.6L, FWD
Old 02-17-2017, 08:56 PM   #48
Crusadernoob's Avatar
Our 06 Duramax I use T/H mode any time I TOW anything, the improved shift points, the T/C lock up in 2nd gear, with the exhaust brake and the aggressive downshifting from being in T/H mode, brakes are for the last 30' of stopping or some jack wagon pulling out in front of me. Wouldn't do it any other way, does our truck NEED to use T/H, no, it would do just fine, but the added benefits of using it are night and day.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 19
Crusadernoob is offline   Reply With Quote
Old 02-17-2017, 11:04 PM   #49
With the Tow/Haul mode on. I only turn the exhaust brake on in the mountains.
2015 GMC Denali 3500 4X4 Duramax
2019 Cedar Creek 36CK2
grumpyoldman is offline   Reply With Quote
Old 02-18-2017, 05:16 AM   #50
DouglasReid's Avatar
In the little black container inside yorur glove box you will find the manuals for your vehicle. Id suggest you read them. The answer to that question is containd inside one of them. (hint) look in the Allison transmission book.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 02-18-2017, 05:42 AM   #51
LOL.......at least the vehicle manuals will provide much more valuable and accurate info which is organized so you can find it better than your trailer manual?
I never knew about holding the T/H button in for 5 seconds on my 2017 2500 to disable the descent assist until I read it in this thread. It works LOL, tried it yesterday.
I have yet to pull the manual from the glove box though.
Mr Havercamp is offline   Reply With Quote
Old 02-18-2017, 07:19 AM   #52
Sorry to hijack your thread. Is it safe to use the cruise control while pulling?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2009 GMC Sierra 1500 Crew Cab
kevin79 is offline   Reply With Quote
Old 02-18-2017, 07:56 AM   #53
Mr. Dan's Avatar
It's safe for me but I can't speak for other pullers.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 0
Old 02-18-2017, 08:23 AM   #54
yetavon's Avatar
IMHO......NO......
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 02-18-2017, 08:31 AM   #55
X2, keep your eyes moving, don't go to sleep.
Old 02-18-2017, 08:44 AM   #56
Yes it is. Keeps me from speeding or slowing down and causing traffic issues.
Old 02-18-2017, 09:06 AM   #57
If I don't I find myself exceeding the rated trailer tire speed, by a lot!
Old 02-18-2017, 09:08 AM   #58
Stevemc's Avatar
Pulling a 40' 5er with a '13 Chevy Duramax. Set tow/haul mode, push exhaust brake button, set cruise control at a safe speed depending on road, traffic and weather conditions. Pulls like a dream.
Steve & Jean
Furbaby - T.J. RIP
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 02-18-2017, 09:10 AM   #59
X2. Even in the mountains.
Old 02-18-2017, 09:46 AM   #60
Originally Posted by yetavon View Post
IMHO......NO......
Do you say no because it damaged the engine or because it is easy to fall asleep?
towing
