Old 02-17-2020, 10:37 PM   #1
HeavyPuller's Avatar
TV Popping Out of Holder
Got a Flagstaff 832 Ikbs. The bracket that holds 42" TV keeps releasing the TV while traveling. I found some self-sticking sandpaper and wrapped the round rubber deal that slides into a "rubber" deal that's supposed to hold the TV in place while traveling BUT that didn't work. Though about screwing two hooks on each of the TV stretching budge cord. Anyone else having this issue - how did you fix it?
HeavyPuller
HeavyPuller is offline   Reply With Quote
Old 02-19-2020, 01:26 PM   #2
Maybe try Museum Putty. It's supposed to hold even in an earthquake.
It works for items in our rig, but don't know if it will hold the weight.
https://smile.amazon.com/Quakehold-8...5WCXS88CYJZ3SB
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 02-19-2020, 02:05 PM   #3
I'll take a look. Thanks
HeavyPuller
Old 02-19-2020, 03:18 PM   #4
NMWildcat's Avatar
When I installed TVs on a wall mount for friends, I also installed strap loops and used a nylon strap/buckle to secure the TV while traveling. So far so good.
https://www.homedepot.com/p/Hardware...13-0/203810635
https://www.amazon.com/TT-57-Xi-26-D...05899980&psc=1
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 02-19-2020, 03:26 PM   #5
Was thinking in that direction. I just need to find the right ones. Thanks
HeavyPuller
Old 02-21-2020, 03:02 PM   #6
TV Mount
Just starting to have the same problem. Considering using some heavy duty Velcro somewhere it can be out of sight when not traveling.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
Beauty and Beast is offline   Reply With Quote
Old 02-21-2020, 04:16 PM   #7
Never thought about the big strips of velcro. Might be able to make that work. Good idea Thanks.
HeavyPuller
Old 02-21-2020, 04:32 PM   #8
one of the bungee cords with a hook on each end, inexpensive and versatile ... should be easy to attach for travel and just as easy to remove for use, ...
fella10 is online now   Reply With Quote
Old 02-24-2020, 07:25 PM   #9
Guess I could put the hooks inside the TV nook, kind out of sight and do the bunge cord and maybe put a towel under the bunge cord to protect the screen. Great idea. Thanks
HeavyPuller
Old 02-25-2020, 08:09 AM   #10
Strange that the locks are rubber. All of the TV mounts we have had the locks are metal and have pull cord to release. Camping work has several examples.
https://www.campingworld.com/search?...t&lang=default
filthy-Beast is offline   Reply With Quote
Old 02-25-2020, 11:21 AM   #11
Might be worth a look-see. Thanks
HeavyPuller
