05-26-2017, 04:28 AM
#21
My routine is to turn off the switch at the water heater AND the circuit breaker. It is not until I have the DW let me know she has water from the faucets in hot and cold that I turn on the water heater switch and circuit breaker.
Making it a habit, each trip, is what I believe to be your long term solution. If you use a written check list, Write It Into the checklist.
Also, if your electric element burns out, you can still use the water heater on propane, AFTER filling it with water of course.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
05-26-2017, 04:50 AM
#22
Originally Posted by campnqueen
Ok so let's sad the electric heating element is cooked.
On a scale of 1 (easy) to 5 (pro to do repair it)....
how hard is it to replace an electric heating element?
I am a woman a little smarter than the average bear. ( no smart comments from the peanut gallery!)
You will need a 1-1/2" 6 point 1/2" drive thin wall socket to remove the element! No a Monkey Wrench will Not work! Youroo!!
05-26-2017, 05:58 AM
#23
They sell a stamped metal socket wrench in the plumbing tools section the big box home improvement stores. I have one and spare element after mine was turned on by the dealer and fried it.
05-26-2017, 06:16 AM
#24
Originally Posted by CHICKDOE
I don't know what model water heater I saw this on, but the water heater electric on-off switch had a small hole through it that you could insert something like a cotter pin through when it was in the off position. so when it is off you insert the cotter pin and when it is inserted it prevents the switch being moved to the on position. also, the electrical wires to the water heater thermostat are attached with terminal lug connectors. I have not done this, but I would think you could remove the rubber cover over the thermostat and remove on of the electrical leads. wouldn't this keep the electric element from getting any power?
I found a photo
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-26-2017, 06:20 AM
#25
Originally Posted by Herk7769
I found a photo
Could attach a flag that says WATER? to the cotter pin.
05-26-2017, 06:28 AM
#26
DW's 401(k) Plan
THAT is a GREAT idea!!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
05-26-2017, 07:00 AM
#27
That's a Suburban WH. I don't think that's good idea pulling those wires off. But you could put the pin back in.
05-26-2017, 04:54 PM
#28
Blue painter tape over the switch. It won't leave residue if not left there forever.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
05-26-2017, 06:11 PM
#29
I control this problem by insuring only one person sets up for all things water.
Step 1 Set heater bypass valves to normal usage.
Step 2 Open pressure relief valve on heater until water comes out while connected
to water
Step3 No power to heater until water out as in step 2.
05-29-2017, 08:44 AM
#30
King of the Road
Originally Posted by BobHanke
Not difficult. Part may be available at Home Depot or Lowes. Needs 5 minutes work and as much over thinking as you like. Look for step-by-step videos on YouTube.
Except for mine. Atwood dual WH has the element in the BACK of the unit. so the entire heater has to be removed to replace it. Needless to say after I fried my element I'm totally propane heat now
Amazon has these as well for you prime members...
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
05-29-2017, 11:01 AM
#31
Is there an access panel behind the WH that enables disconnection of the water lines to remove the WH and operate the bypass valves? If so, you can probably change the heating element through there too.
06-06-2017, 02:04 PM
#32
King of the Road
Haven't found one, but working on my slide so have cut open the underbelly for that. After I have that all buttoned back up will move to under the water heater and open that and have a look see.....
2016 Crusader Lite
Single slide
