To turn the water heater off? I tell myself to tell Google to set an alarm when I turn it on but then I forget to do that too. I wish it had a light that stayed on. It's hell getting old.
I install the lighted switch right by the door that is lighted so whatever we can leave the camper we can see inside we can shut it off that's helped a lot.
I forget something new every trip. I usually figure it out. Most times it has not cost me too much. Only once was it over 100 to fix...i get into a routine but each time there is something just a bit different...either no water and I am on the tank or no sewer and I am not. Once no power and another forgot a chock. Another time a storage door. Lots of walking around helps now too. I still forget but I catch it before I leave now.
List are the best way I think to go !!!
We start a list of things we need to do & want to take,,, weeks before we plan to leave,,, we normally add some thing to it most every day,,, we keep the list from the trip before we use that to start our new list,,, we also keep a short list in our unit,,, when we are out and find something we want for next trip we add it to the lists !!!
Sorry to say but we have lists & notes every where,,, but we forget less than our kids do !!! Using lists & notes should be added to the 3 Rules of Getting Older !!! LOL !!!
I added this to the shore power plug when Plugging in. Reminds me to turn water heater off when unplugging
These work very well for a lot of things. We put up those little 3m command hooks at each place we needed to make sure we took care of, before we headed out and place one of these at each of them, as we turn them on, unhook them, etc. We also place one on the antenna crank as we deploy it upon arrival. Then leaving, we take the tags off of the hook as we stow, turn off, etc. We know we have 5. Before we lock the door, we count the tags and if we don't have 5 on the large hook inside the door, we know we forgot something.
If you have a driveable RV, you can use these, or the strips, which wrap around your steering wheel. You don't have to count those, you put the strip on your steering wheel as you set whatever up, then when you are leaving, you remove the strip as you stow whatever.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
There was a member a while back that hung his keys on the antenna crank so he would not forget to put antenna down before they left !!!
I thought that was a GREAT idea !!!
Yeah that's the thing. I used to be a pilot and had the check lists. But that was life or death stuff. Most of this stuff isn't. I could probably drive around with the antenna up 90% of the time and it wouldn't matter. My worst screw up so far was leaving a deck chair leaning against the rig when I let the jacks down. The chair got caught on the generator door hinge. Luckily for me the hinge was stronger than the chair and bent the chair. Imagine if it ripped the hinge off. What a mess. Now I always walk around the coach before I retract the jacks. I won't be forgetting that one soon!
Not sure about the antenna thing,,, we might make it a mile down the road before it got RIPPED OFF !!!
Potatoes chip bag clips on the steering wheel work great. You can write on each one what you need to check before you take off. Of course you have to remember to put them on the steering wheel!
Put a label on the door so when you lock it up to leave its right there in front of you to remind you.
I have a small check list above the door on the inside that I use before closing the door and locking for the last time before leaving a site. Some of the items are:
TV Antenna down
Vents closed
Hot water heater off
Refrigerator to gas
Microwave secured
Oven pilot light off
Stove burners all off
Heat / AC turned off
There are more. It is just a typed up list of things to remember. Cut down and placed above the door(you could even put it in a small frame and hang it near the door) Since DW does some of the things and I do others. One of us will read it out loud so we can make sure we got everything.
The way we do it is the wife secures the inside & I do the outside !!!
We also make sure the dog in inside !!! LOL !!!
This time the wife was not sure the Toilet lid was closed,,, so after we hit the road she had to climb to the back and check !!! Just one more thing to remember !!!!
So does mean that now that we're old, the lights aren't on???
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
