06-22-2017, 01:46 PM
#21
There are two different ways per reefer manufacturer. Some have pan some are routed outside.
In both instances if you want the reefer to cool optimally then a trap loop should be put in the hose. Then prime it with water at the start of the season. This keeps the hot air out of the reefer.
You will be surprised at how much better the reefer cools in hot summer temps.
06-22-2017, 02:04 PM
#22
I installed flying bug screens on my refridge vent cover and didn't recall seeing the drain line routed outside prior to this install. I checked yesterday and indeed the drain line was just chilling in the vent area. This weekend I will modify the screen and route the hose through the vent cover. Good heads up there and thank you.
Dometic install manual excerpt
06-22-2017, 02:25 PM
#23
Originally Posted by Herowe
Ours was just hanging inside. I rerouted out the vent. But, I also curved it up and out the top vent so it formed a small trap.
That keeps a little water in the line. Otherwise, you have a small hole leading right into the back of your fridge for outside hot air.
Our last trailer we bought used. The tube was all crumbled and broken hanging straight down. The fridge never worked well until I replaced it and put the small trap bend in it. That change made a 7 degree difference in the operation of the fridge.
Unless your door seals are leaking, I doubt you're going to get much hot air up that drain line. The air can't go in unless there's somewhere else it can get out.
2011 Traverse LT, 3.6L, FWD
06-22-2017, 06:18 PM
#24
It may not have been Forest River, it could have been the dealer who, in the prep had some moron of an employee take the fridge vent off and not put the drain tube back through the hole to the outside.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
06-22-2017, 11:45 PM
#25
Just a question about the catch pan method. What happens to the pan and its contents when you are highway-ing down a county road?
06-23-2017, 12:51 AM
#26
Its screwed to the wall.
06-23-2017, 07:01 AM
#27
Originally Posted by 5picker
I agree... could have been the factory but more likely the dealer forgot to pull it through the vent door when checking the unit from new. Mine will sometimes try to pull itself back into the rear compartment if I didn't quite pull it through the vent enough.
A good thing to check though none the less.
I'll often peek at my drain to see if it's making water.
Right On,,, Dealer Job !!!
06-23-2017, 10:40 AM
#28
Originally Posted by rockfordroo
Mine's OK. I did enlarge the hole in the grille that it was stuck through, so I could get it in/out easier when I remove the grille. Wish it was 1/2" longer.
Sounds like my problem! 🙀
06-23-2017, 08:43 PM
#29
Just as confused as you
I pulled mine out far enough that it comes out the louver then rests against the bottom causing it to curve outward about an inch from the TT side.
Richard & Jill
06-29-2017, 01:13 PM
#30
Can someone help me identify my drain on the fridge please. Is it the cap on the condenser and should it be ran outside the cubbie hole?
06-29-2017, 01:35 PM
#31
...a small trap.
I replaced the drain line in our last TT.
There was no trap in the line before; when I tried to put one in afterwards the catch tray inside the fridge wouldn't drain.
So, no trap for us. And the fridge always worked just fine.
I don't think our new-to-us Rockwood has a trap in the line either.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
06-29-2017, 01:41 PM
#32
I think your drain line is that copper line going into the black corrugated plastic tube. My drain line looks like the black corrugated tube. Your second pic is part of the ammonia cooling cycle piping.
06-29-2017, 01:45 PM
#33
The cooper line with corrugated tube is my gas.
06-29-2017, 02:03 PM
#34
The drain line should run from the outlet of the drip tray inside the reefer to the outside through your exterior cover Without any trap whatsoever, or it will not drain properly. The small white plastic cap on the corregated hose shown in the picture above prevents mud daubers, etc. from plugging it.
It may be above the opening and you may have to pull it down or even move your reefer forward to access it. there is another thread on here where one camper had the line that was not run to the outside and all the water had caused damage inside the camper to the floor. You should find it and rout it to prevent this.
06-29-2017, 02:21 PM
#35
That is *this* thread.
06-29-2017, 02:29 PM
#36
Of course it is!
06-29-2017, 02:30 PM
#37
OK, I goofed.............SHOOT ME!
06-29-2017, 02:51 PM
#38
No, the hose was long enough to make it through and the vent openings were large enough also.
Hank, Dianna and two fur babies Cody and Bella
2016 F250 PSD CC/SB
2018 Crusader 338RSK
06-30-2017, 05:41 AM
#39
I have seen units where the drain line runs thru the unit and drains out the bottom,,,
No stupid little hose to stick out the vent door !!!
VERY NICE !!!
06-30-2017, 06:42 AM
#40
The only time I've seen the tube sticking out the vent cover is before the TT had been prepped by dealer. The three trailers I've owned, all had an evaporation tray on the inside of the compartment which the tube drained to, exactly like your refrigerator at home.
