Originally Posted by mdecheser
Hi!
New to this site.
I have a 2013 Flagstaff 176LTD.
It has a 4 pin hitch wiring. My truck has a 7 pin.
Three Questions:
1. The camper battery does not recharge when in tow. Can this be added (add 7 pin?) and is that an easy conversion?
2. The camper has its own braking system but not sure its operating. Does this also require a 7 pin to operate?
3. When camper is set up, and 110 electric hooked up, does that recharge the battery?
Thanks in advance!
1) As you stated, the Flagstaff 176LTD only has a 4 pin plug so it doesn't get any power from the tow vehicle. It only has Ground, Tail Lights, Left Turn/Stop, and Right Turn/Stop. So it doesn't charge the RV battery from the tow vehicle.
2) Unless someone added brakes the 176 doesn't come with brakes. It was an option, but if it came with brakes it would have a 5, 6, or 7 pin plug.
3) This RV does come with a converter/charger, so it powers the 12 volt system and recharges the battery when plugged into shore power.
Adding a 7-way plug to charge the RV battery from the tow vehicle isn't a terribly complicated job, but it's not as simple as just plugging something in.
