Old 06-08-2018, 08:20 PM   #1
80 watt solar panel w/controller
If I connect a portable 80 watt solar panel unit to my single 12 volt DC battery via alligator clips, do I need to disconnect the wiring from the inverter to safely charge the battery? Thanks for input.
TerryLittle is offline   Reply With Quote
Old 06-08-2018, 08:28 PM   #2
Flybob's Avatar
No, but you do need to have a charge controller between the battery and the panel.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-08-2018, 10:32 PM   #3
Do have controller
There is a controller. I just did not want unwanted voltage from panels to damage inverter is why I asked about disconnecting.
controller, solar, solar panel
