Old 08-20-2020, 10:51 PM   #1
AC DC
Iím new to pop up world.
I was told run dc power to fridge while driving then switch to AC when I set up and hook into RV park power. Is this correct?
Thank u
Stroopedog is offline   Reply With Quote
Old 08-20-2020, 10:58 PM   #2
rsdata's Avatar
start with fridge on AC in the driveway if you can 24 hours before leaving... start filling fridge with cold stuff, and a couple of bottles of frozen water helps... when you pull out turn off fridge and it will stay plenty cold for about 2 days of traveling... DC may kill your battery depending on the actual fridge because DC is a power hog
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 08-21-2020, 07:09 AM   #3
Head Rambler
Thank u
If it's a 3 way fridge it would be better to run it on propane, but if it's just 12 volt or 120 volt then running it on DC power while towing is correct.
We could give better help if we knew the model number of the fridge.
Gotta go campin!
Old 08-21-2020, 06:27 PM   #4
Thanks for taking time to help a new guy
