You probably already know this, but lets go over it again.
The switch inside the RV is for LP operation,
The switch in the heaters outside access area is for 120 volt operation,
You turn the inside switch on when you want the heater to operate on propane and turn the outside switch on when you want the heater to operate on shore power. You can have them both on at the same time for faster recovery if you want.
You are correct, for high altitudes electric is most likely the way to go as long as it's available.
Gotta go campin!
