Old 12-15-2018, 11:27 AM   #21
bubbles's Avatar
Originally Posted by Detourkid View Post
Thanks ..
I kinda want it inside ..
I guess I am an electronic junkie..
I just bought a inside and outside thermometer that lights up blue ..
Here's a down and dirty voltmeter panel made from thin hobby plywood, sprayed heavy with Rust-Oleum Hammered paint, a simple cheap press to actuate switch and a cheap voltmeter from Ebay. Wires connected to a direct battery output source (battery hot side directly). It's just a voltmeter and will indicate battery voltage and whether battery is being charged or not. With the press to test there is no parasitic draw and not affected by battery disconnected or not.
Old 12-15-2018, 11:52 AM   #22
Detourkid's Avatar
Bubbles nice job
2007 Rockwood pup #2280
Toyota FJ Cruiser
Ok can we go camping now..
Detourkid is offline   Reply With Quote
Old 12-17-2018, 10:28 PM   #23
Try this mod I posted earlier.
http://www.forestriverforums.com/for...ml#post1295889
dfazzini is offline   Reply With Quote
Old 12-28-2018, 05:12 PM   #24
VinceU's Avatar
Originally Posted by babock View Post
The length of the lead doesn't matter at all.
Something called voltage drop esp with low voltage DC circuits can be very important. Longer wire= more resistance, heat and less power available.
Old 12-28-2018, 05:28 PM   #25
The current draw (microamps), and hence voltage drop in the wiring of a voltmeter is meaningless compared to our other 12V accessories.
The leads to my permanently installed Drak digital voltmeter ($8 Amazon) are 20 gauge. I used 14 gauge wire (about 5ft) to connect the voltmeter to the nearest 12 volt source because that's what I had on hand.
Fred W
2019 Flagstaff T21TBHW A-frame
Old 12-28-2018, 08:44 PM   #26
The small little voltmeter I bought that has an LED display is around 10mA draw. LOL It could be 100 feet away and it wouldn't matter.
babock is offline   Reply With Quote
Old 12-28-2018, 11:56 PM   #27
Detourkid's Avatar
Ok thanks great info
Toyota FJ Cruiser
led
