11-29-2021, 10:01 AM
Anyone know where I can get this part for my dometic awning?
Thanks for looking at this, I hope someone has the answer. Dometic parts for bag awnings seem to be impossible to find.
I have a HW276 with a Trimline Bag Awning. One of the support legs is missing the end cap that is tethered to the pole shown in this image. Anyone know where I can get that?
11-29-2021, 11:01 AM
Have you contacted the manufacture directly? Sometimes this is the best solution to an issue!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
11-29-2021, 11:04 AM
Im going to try today. They seem to be geared towards resellers rather than retail and they consider this awning "legacy" despite only being a couple of years old.
I find a parts diagram and what they point to on the diagram says "Stake loop" rather than "Cap"
12-02-2021, 10:36 PM
Not sure if this will help with your search, but they appear to have different MM Pole Caps available. Might be worth checking into.
https://www.ebay.com/itm/19271675306...Cclp%3A2047675
Rick & Brian
2023 Flagstaff 206STSE
2019 Flagstaff HW29SC ( sold )
2017 Salem Cruise Lite 232RBXL ( sold )
2014 Ford 150 XLT 5.0 2wd
12-03-2021, 08:07 AM
Awning part
I ordered a complete awning kit for my FR Rockwood Freedom from Dyer's RV Supplies. They had the best price but it took 2 month since it was made to order. The awning was drop shipped directly from Domestic. I will give you a cap if I still have one off my old awning if you pay the postage.
P.S. Make sure you slope your awning if you leave it up when away. We had no rain forecast so left awning up when we went hiking. Pop up shower hit the campground and destroyed our awning. Bent the frame and tore the fabric.
12-03-2021, 08:15 AM
Part-Time Campground Host
Craig & Cath
Days camped since 2015(retirement): 1687
I will give you $40 for both and shipping if that is fair. Can you drill out the rivet holding the string on at the pole so I can reattach?
12-03-2021, 08:29 AM
End cap
Send me a private message with your contact information. I will go out and check which parts I have left and let you know. I think I kept most of the frames for extra parts.
12-03-2021, 09:29 AM
Attachment 266202
If you have no luck sourcing a cap here is another option.
I don’t know if this would work for you or not. But if you have or know someone with a 3d printer that cap could be easily made to pretty much any size.
12-03-2021, 01:04 PM
Info on Dometic parts, apparently discontinuing many. I found seller on e-bay picking up used pieces and reselling. He also has a shop making parts that are not available. A little pricey, but if you need them, cheaper than replacing complete unit.
dart5560 is his selling name, use the e-mail between the arrows.
eBay - dart5560 <deplor_ivdl3298md@members.ebay.com>
I needed the end plugs for the Sunchaser ll
12-04-2021, 08:27 PM
I think I am just going to have to take it to our engineering lab and 3D Scan and then Print them :/
12-24-2021, 12:12 PM
Hope it was a success. I need the same thing.
_____________________
2022 Rockwood Roo 235S
2020 Toyota Tundra Platinum
Husky Centerline TS WD Hitch
12-24-2021, 01:31 PM
Hadn't done it yet. Going to have it out next week after Christmas for a trip so plan to remove the remaining one then and have it scanned and printed. May get a dozen printed if it turns out good. They have some high $$$ equipment so it should be spot on.
12-24-2021, 02:56 PM
why not go buy a pvc/cpvc end cap at hardware store inside diameter of pvc is different than cpvc inside diameter. a little Dremel tool work or a drill and a bit with stone end for grinding. drill hold in end of cap and put in a cotter pin ,loop end out . 3/4 s lenght of pin should be fine, insert and spread ends. paint it
black.
12-27-2021, 10:15 PM
I have one and you’re more than welcome to have it. I reside in Florida, message me if you want to pay the postage and I’ll send it out ASAP.
12-27-2021, 11:21 PM
Originally Posted by Amartin453
Attachment 267127Attachment 267128
Thanks, PM sent.
01-06-2022, 10:34 PM
Thanks so much to Amartin453 ! I just got it from the mailbox this afternoon and tried it out. Works Perfectly! Thanks again!
01-19-2022, 06:44 PM
If anybody has another one or two, I could sure use them. Thanks.
01-20-2022, 10:30 AM
I'm waiting on my 3D printer to arrive, when it does I may print a few out of polypropylene which should be flexible like the original. I can offer those up once I figure it all out.
Its coming from the Czech Republic so it will be a little while
01-20-2022, 12:20 PM
Thanks for letting me know. I can wait. Appreciate the response.
