Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-29-2021, 10:01 AM   #1
Anyone know where I can get this part for my dometic awning?
Thanks for looking at this, I hope someone has the answer. Dometic parts for bag awnings seem to be impossible to find.
I have a HW276 with a Trimline Bag Awning. One of the support legs is missing the end cap that is tethered to the pole shown in this image. Anyone know where I can get that?
flyerdp is offline   Reply With Quote
Old 11-29-2021, 11:01 AM   #2
Jim34RL's Avatar
Have you contacted the manufacture directly? Sometimes this is the best solution to an issue!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 11-29-2021, 11:04 AM   #3
Im going to try today. They seem to be geared towards resellers rather than retail and they consider this awning "legacy" despite only being a couple of years old.
I find a parts diagram and what they point to on the diagram says "Stake loop" rather than "Cap"
Old 12-02-2021, 10:36 PM   #4
Briorick's Avatar
Not sure if this will help with your search, but they appear to have different MM Pole Caps available. Might be worth checking into.
https://www.ebay.com/itm/19271675306...Cclp%3A2047675
Rick & Brian
1 Happy Camper Pup ( Mya )
2019 Flagstaff HW29SC
2017 Salem Cruise Lite 232RBXL ( previous )
2011 Ford Super Duty 250 XLT FX4 6.2
Briorick is offline   Reply With Quote
Old 12-03-2021, 08:07 AM   #5
Awning part
I ordered a complete awning kit for my FR Rockwood Freedom from Dyer's RV Supplies. They had the best price but it took 2 month since it was made to order. The awning was drop shipped directly from Domestic. I will give you a cap if I still have one off my old awning if you pay the postage.
P.S. Make sure you slope your awning if you leave it up when away. We had no rain forecast so left awning up when we went hiking. Pop up shower hit the campground and destroyed our awning. Bent the frame and tore the fabric.
JJenkins is offline   Reply With Quote
Old 12-03-2021, 08:15 AM   #6
Just Tryin' to Help
cboss's Avatar
Try something aftermarket like this:
https://www.amazon.com/Flexible-Rubb...652120740&th=1
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1142
cboss is offline   Reply With Quote
Old 12-03-2021, 08:15 AM   #7
I will give you $40 for both and shipping if that is fair. Can you drill out the rivet holding the string on at the pole so I can reattach?
Old 12-03-2021, 08:29 AM   #8
End cap
Send me a private message with your contact information. I will go out and check which parts I have left and let you know. I think I kept most of the frames for extra parts.
Old 12-03-2021, 09:29 AM   #9
Scubanut's Avatar
Attachment 266202
If you have no luck sourcing a cap here is another option.
I donít know if this would work for you or not. But if you have or know someone with a 3d printer that cap could be easily made to pretty much any size.
Scubanut is offline   Reply With Quote
Old 12-03-2021, 01:04 PM   #10
Info on Dometic parts, apparently discontinuing many. I found seller on e-bay picking up used pieces and reselling. He also has a shop making parts that are not available. A little pricey, but if you need them, cheaper than replacing complete unit.
dart5560 is his selling name, use the e-mail between the arrows.
eBay - dart5560 <deplor_ivdl3298md@members.ebay.com>
I needed the end plugs for the Sunchaser ll
boatcat AH6NR is offline   Reply With Quote
Old 12-04-2021, 08:27 PM   #11
I think I am just going to have to take it to our engineering lab and 3D Scan and then Print them :/
Old 12-24-2021, 12:12 PM   #12
Hope it was a success. I need the same thing.
deano55 is offline   Reply With Quote
Old 12-24-2021, 01:31 PM   #13
Hadn't done it yet. Going to have it out next week after Christmas for a trip so plan to remove the remaining one then and have it scanned and printed. May get a dozen printed if it turns out good. They have some high $$$ equipment so it should be spot on.
Old 12-24-2021, 02:56 PM   #14
why not go buy a pvc/cpvc end cap at hardware store inside diameter of pvc is different than cpvc inside diameter. a little Dremel tool work or a drill and a bit with stone end for grinding. drill hold in end of cap and put in a cotter pin ,loop end out . 3/4 s lenght of pin should be fine, insert and spread ends. paint it
black.
Thomas ho is offline   Reply With Quote
Old 12-27-2021, 10:15 PM   #15
Amartin453's Avatar
ID:	267127Click image for larger version
I have one and youíre more than welcome to have it. I reside in Florida, message me if you want to pay the postage and Iíll send it out ASAP.
Amartin453 is offline   Reply With Quote
Old 12-27-2021, 11:21 PM   #16
Originally Posted by Amartin453 View Post
Attachment 267127Attachment 267128
Thanks, PM sent.
Old 01-06-2022, 10:34 PM   #17
Thanks so much to Amartin453 ! I just got it from the mailbox this afternoon and tried it out. Works Perfectly! Thanks again!
Old 01-19-2022, 06:44 PM   #18
If anybody has another one or two, I could sure use them. Thanks.
Old 01-20-2022, 10:30 AM   #19
I'm waiting on my 3D printer to arrive, when it does I may print a few out of polypropylene which should be flexible like the original. I can offer those up once I figure it all out.
Its coming from the Czech Republic so it will be a little while
Old 01-20-2022, 12:20 PM   #20
Thanks for letting me know. I can wait. Appreciate the response.
awning, dometic
