Old 07-28-2024, 07:04 AM   #1
Automatic Crank Safety Cable
While camping last weekend, the yellow safety cable detached from the front inside support. I can't seem to find a way to reattach it online. Anyone have instructions? I'm not referring to a lift cable, I was told by the dealer it was simply a safety cable for the lift system.
TIA
hockeytownmom is offline   Reply With Quote
Old 07-28-2024, 09:13 AM   #2
what system are you asking about?
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 07-28-2024, 09:32 AM   #3
I think it's a Goshen. 2016 Premier 2317g.
Old 07-28-2024, 11:47 AM   #4
Oaklevel's Avatar
Rockwood??? 2016 Premier 2317g.
Pictures might help.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
Old 07-28-2024, 11:51 AM   #5
I've been googling. It's the height gauge cable that indicates the roof is at the proper height. Unfortunately, it's in storage, so I'm unable to post pictures.
Old 07-28-2024, 11:52 AM   #6
Yes, Rockwood.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
Old 07-28-2024, 12:07 PM   #7
I was able to find a photo.
https://www.forestriverforums.com/fo...ht-169288.html
Scroll down for photo.
Kristina
2021 F150 XLT
Previously:
Old 07-28-2024, 12:09 PM   #8
That thread answered all my questions! Lol.
Kristina
2021 F150 XLT
Previously:
Old 07-28-2024, 01:30 PM   #9
Smile It's ALL there!
It's all there. You just have to be able to find it. Google is pretty good for that.
Larry
Larry-NC is online now   Reply With Quote
Old 07-28-2024, 02:24 PM   #10
I googled, but I didn't know what I was googling for at first.
Kristina
2021 F150 XLT
Previously:
Old 07-28-2024, 05:03 PM   #11
Not this case
Doesn't apply in this case, but in some instances where I don't know the terminology, I put an image in Google Lens and it finds the right part and names it.
Larry
Old 07-29-2024, 12:40 PM   #12
TIA
If you are talking about a popup camper, and you are talking about the "safety cable" that tells you when the top is all the way up, there is no trick to re-attaching them. The cable is just a lightweight cable with crimp-on eyes on either end. Screws through the eyes hold it in place. When the top is raised to the max, the cable is taught.
I see other similar responses, so mine is somewhat redundant. I've had 2 popups prior to my current rig.
If I'm on the right track, one or both screws may have vibrated out or been stripped out because they are screwed into an aluminum rail around your tub and roof. If you have one screw still in place, remove it and go to a hardware store and buy a pair of similar screws one size larger than the original. Reinstall the cable with the new screws. In the case of an upper screw into "wood", that ain't wood. It's likely to be particle board...not much more that glued/pressed sawdust. A larger screw or new hole is all you need. That's all there is to it.
If, after years of use, one of the eyelets have come off the end of the cable, you can buy a crimping tool and new eyelets at the hardware store. A worthwhile investment you will use far more than you expect. If the wire is 1/4" shorter, it won't hurt anything. It's just a tell-tale to let you know to stop raising the roof. 1/4" less is unlikely to cause you problems.
RECOMMENDATION: Do NOT raise the roof so this tell-tale cable is TIGHT. It can be snug, but not tight. When raising my roof, I'd operate the lift switch with one hand and hold the tell-tale cable in the other. As the tell-tale started to get snug, I'd stop. In fact, once you place the door into the opening, it's often necessary to lower the roof slightly for a good fit. That tell-tale cable signifies the MAX to raise the roof. If you have an electric motor lift, there may be limit switches in the mechanism to stop the lift before it causes damage, but your limit switches may allow the roof to be raised to the point that it ripped out the tell-tale cable.
Don't get me started on limit switches. They are mostly a lot of trouble, but the one thing they are really good for is when some kid decides to "see what this switch does" and starts lifting your roof until it breaks something.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
jimmoore13 is offline   Reply With Quote
cable, safety
