03-05-2023, 08:16 AM
Battery maintenance
What is the best method to keep the battery on your pop up maintained? Trickle charger?
2021 Rockwood Freedom 2280 LTD
03-05-2023, 08:36 AM
I have a trickle charger permanently mounted but do not have it always plugged in. In the summer months, if it has not been used in the last 30 days, I plug it in for about 24hrs just to keep it up to capacity. I also charge the battery before I head out. In the winter months, I take the battery out and put it on my work bench and charge it about once a month.
2013 Rockwood Freedom2381G
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
03-05-2023, 09:02 AM
If the battery is just sitting it doesn’t drain at a high rate. I always bring the trl to the house at least a day before trip, so I plug in the trl let it charge. If your pop up doesn’t an inverter then yes a trickle charger over night
2019 F 250 6.2
2022 Columbus 329 DVC
03-05-2023, 10:08 AM
Do you recommend a trickle charger permanently mounted? I like that idea.
I keep my pop up in the garage, so power is available.
03-05-2023, 10:38 AM
Kanadian Kamper
Having an inverter has nothing to do with keeping the trailer batteries in check.
An inverter provides AC power from DC batteries.
A converter can charge DC batteries from AC power.
A trickle charger just keeps batteries at their optimum without overcharging.
Search “Battery Tender”
If applicable, you still need to monitor the water level of batteries that aren’t sealed units.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
03-05-2023, 10:41 AM
If it is a trickle charger with some kind of regulation, then it would be OK to install and leave on.
A fully charged and disconnected battery will maintain almost a full charge for many months. I've never kept a battery on any kind of trickle/maintainer charger when stored. Simply charge to capacity and disconnect.
Days Camped: '18=48 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=112 ☼ '23=83
03-05-2023, 10:45 AM
Plug the trailer shore cord into a garage outlet.
Let the trailer's converter do what it's designed to do, keep the battery charged. Just check the battery cells fluid level once a month.
03-05-2023, 11:11 AM
x2
03-05-2023, 01:26 PM
I do what Dan & Larner said above. I installed a battery cut-off switch also. I charge for 24 hours every 6 weeks, when I'm not charging I turn my cut-off switch on, so there's nothing slowly draining the battery.
2018 Flagstaff HW27ks
2019 Toyota Tundra
03-05-2023, 02:00 PM
You are correct used the wrong term
2019 F 250 6.2
03-07-2023, 10:26 AM
EITHER: 1. Disconnect the battery. Remove all wires from one post or the other, or install a disconnect switch. Leave the battery alone for up to 6 months.
OR: 2. Keep the battery charged with the converter or trickle charger.
Either method works. Some prefer one over the other. Sometimes I use #1, sometimes I use #2.
Fred W
2019 Flagstaff T21TBHW A-frame
2022 Hyundai Flagstaff
03-07-2023, 07:26 PM
Thanks everyone. This gives me good insight.
03-07-2023, 07:57 PM
On most battery disconnect switches, the "ON" position means the battery is connected, the battery is turned "ON". The "OFF" position means the battery is turned "off", it is disconnected from the loads on the load side of the switch. Sometimes the disconnect switch will have another position that allows you to remove the "key" or handle when in the "OFF" position with the battery disconnected.
From the factory, the propane leak/CO detector will be wired to the battery itself and not disconnected with the switch which will draw a small load off the battery.
03-07-2023, 08:04 PM
Old man RVer
What kind of battery?
The OP never stated what kind of battery he has, did he? Is it lead-acid or li-ion? Lead-acid - use a "smart" trickle charger, the TT's charger or disconnect and charge congressionally. Li-ion - drain to 50% and leave it be.
03-07-2023, 08:31 PM
Originally Posted by 2WheelJon
... or disconnect and charge congressionally. ...
OK, I'll bite. What does that mean?
TV: 2016 Ford F-150 RWD Lariat Crew w/ 3.5L EB, MaxTow and tow mirrors.
03-07-2023, 08:52 PM
Well, to charge your battery like congress I would assume means there would be absolutely nothing done to the actual battery at all
Scott and Liz - Southern NM
03-07-2023, 08:53 PM
I'll guess its "auto-correct speak " for " occasionally ".
2004 Nissan Titan
03-07-2023, 10:27 PM
NMWildcat's explanation is equally plausible.
03-07-2023, 10:38 PM
Very
2004 Nissan Titan
03-07-2023, 11:36 PM
Yeah, I worded that oddly. I meant I turn it on to the off position!
2019 Toyota Tundra
