By its nature, a series connection always has to draw the same current through all connected batteries. You are correct that parallel batteries do not always charge or discharge equally; however if the batteries are the same age , type, and brand the difference in actual use is of little significance. I added a second 75 AH group 24 battery to my rig with a simple parallel connection. Works fine.
