06-01-2022, 10:09 AM
Battery Question
2022 2318G. I haven't checked to see if this pop up has a battery disconnect but I assume that when you are connected to shore power then the rectifier is charging the battery? Also, do folks disconnect the battery when not camping and add a trickle charger?
06-01-2022, 11:23 AM
Yes the battery should be getting charged by the WFCO power converter (where the breakers are). I have a battery disconnect on mine, I used to take off the battery terminal.
Several things draw power even while closed which is why you want to disco. the battery.
I use a battery maintainer to keep it charged while not in use. Was a fathers day gift last year
06-01-2022, 12:29 PM
Originally Posted by flyerdp
Yes the battery should be getting charged by the WFCO power inverter (where the breakers are). I have a battery disconnect on mine, I used to take off the battery terminal.
Shouldn't that be CONverter, not INverter?
I wasn't aware that any FR popups came with an inverter.
Sent from my SM-G781U using Forest River Forums mobile app
06-01-2022, 12:41 PM
You can either trickle charge the battery or if you don't have electricity, disconnect the negative cable. Personally on our tt, wepreferred disconnecting the negative cable. Less worry about remembering to restart the battery maintainer in case of power failure.
2015 Dynamax REV 24TB class C
06-01-2022, 12:43 PM
My mistake... converter for 120vAC to 12vDC inverter from 12vdc to 120vac.
06-01-2022, 03:48 PM
Thanks for all the replies! I will look at the battery disconnect. I will put an ammeter on it this afternoon to see what kind of drain I am seeing from the load.
06-01-2022, 03:59 PM
As I said in post #3, FR popups don't have factory battery disconnect switches unless that changed for the 2022 models.
06-02-2022, 08:16 AM
I suspect he was going to "Look in to" battery disconnects
06-02-2022, 09:08 AM
Looks like the other posts have you covered, but I might as well reply too. :-)
We have the same camper (2021 2318G). No disconnect switch, but I've run an extension cord to the battery box from an outside outlet and keep a Battery Tender Jr. connected to the battery when the camper isn't in use. It's a smart charger, so no worries about overcharging. The tender gets disconnected from time to time when it's needed elsewhere, but it doesn't hurt the camper's battery if the charger is left off for a few days and then the charger restored.
2021 Rockwood Freedom 2318G
2022 Chevrolet Colorado LT V6
2019 Dodge Durango Citadel 5.7l
06-02-2022, 09:26 PM
I recently added a battery disconnect switch to the side of my battery box along with an SAE port on the box. I park it in the garage, flip the switch, then plug in my battery tender to the SAE port. I'm also now using that port for my solar. My "solar on the side" is up front, down low, behind the propane tanks and battery so it's kind of a pain to get to. And its polarity is reversed from standard SAE ports (which isn't a huge deal really).
06-02-2022, 09:33 PM
There is no battery disconnect or external fuse to use as a battery disconnect. There is only the battery fuse in the converter's fuse panel.
So I just disconnect the battery cable from the negative. Forest River's video shows disconnecting the battery when it's not in use.
I definitely disconnect the battery cable with having the power lift system as someone activating the switch while the roof is clamped down, can damage the lift system severely.
I use the converters battery charger and works great. No sense in using an external battery charger when there's one built in.
2024 Black Jeep Grand Cherokee L Altitude 4WD, 121" WB, 3.6L, 8 speed, Blacked Out Package, 265/50R20 wheels, 6,200# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Go through Indiana Dunes NP 5X/week! Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet.
06-02-2022, 10:22 PM
But you can't use the converters battery charger if you have the battery disconnected.
06-03-2022, 09:32 PM
In that case I leave the power lift system cable disconnected from the battery but leave the camper electrical system connected to the battery since I don't have to worry about battery drainage and ultimately battery cell warpage.
