Old 09-20-2017, 03:30 PM   #1
Beeping in my closed popup. Any ideas?
Any idea what's causing beeping in my closed Rockwood 1640ltd? Was boondocking last week and pretty sure battery is low.
sjlemi is offline   Reply With Quote
Old 09-20-2017, 03:32 PM   #2
fonzie's Avatar
Either the LP/CO detector or smoke detector.
Fonzie
Old 09-20-2017, 03:39 PM   #3
So is it the battery or should I open it and check everything?
Old 09-20-2017, 03:42 PM   #4
King of the Road
I would have opened it to check everything before I posted this question.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
Old 09-20-2017, 03:44 PM   #5
I'm not there right now, still at work. My wife informed me
Old 09-20-2017, 03:45 PM   #6
Bikersarge's Avatar
Heavy Fog will cause some smoke detectors to go off if door is left open, happened to me the other day. The sensor picks up the water particles and thinks its smoke.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
Bikersarge is offline   Reply With Quote
Old 09-20-2017, 03:48 PM   #7
lmiken's Avatar
Well, now you need to open and check it out. If it the LP/CO detector checking the flashing light on what the warning is. If propane is off, most likely it will be flashing low battery.
2015 Flagstaff 32IKBS
2008 F350 6.4
1999 Palomino Filly Popup (my daughter's now)
lmiken is offline   Reply With Quote
Old 09-20-2017, 03:52 PM   #8
Opening it when I get home. Will update after that
Old 09-20-2017, 04:04 PM   #9
Curious. Do these "smoke detectors" detect everything but smoke?
seagrace is offline   Reply With Quote
Old 09-20-2017, 04:21 PM   #10
Broken Toe
Cowracer's Avatar
Its probably the Smoke Detector chirping to let you know to replace the battery. Most chirp once every 20-30 seconds when its time. Be aware that they are not wired in to the campers 12 or 120 volt systems. they have 9volt batteries in them
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 09-20-2017, 04:28 PM   #11
Flybob's Avatar
OP says it all. If the battery is low and it is still connected to the 12V system ( no battery cutoff) then the Co/Propane detector is sending a low voltage alarm. Charge the battery and add a cut off switch or disconnect the negative battery terminal. Just remember to reconnect the next time you hook up as battery powers the break-away system.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-20-2017, 04:37 PM   #12
Wrench Turnin Fool
Arctic Wolf's Avatar
My propane detector beeps when the battery dies, maybe that's all it is.
Arctic Wolf is offline   Reply With Quote
Old 09-20-2017, 06:52 PM   #13
The LP/CO detector is hardwired to the battery. The smoke detector is battery operated. I always take off the pos terminal off the battery if I am parked for more that a week. Once you are plugged in for a bit and charged, everything should clear itself.
MCamper09 is offline   Reply With Quote
Old 09-20-2017, 07:24 PM   #14
Yo
The carbon monoxide alarm has a three year shelf life
My dogs flipped out when it failed and then of course so did I lol
Anyhoo change it out your good to go
stonefly is offline   Reply With Quote
Old 09-20-2017, 07:49 PM   #15
So, I plugged in the camper to power, never opened it but beeping stopped. Low battery alarm, I don't have a 7 pin connector on my truck but use a converter to make the 4 pin a 7 pin. When I'm driving connected its not charging . I think that was it.
Old 09-20-2017, 09:28 PM   #16
Thanks everyone for the help
Old 09-21-2017, 12:35 PM   #17
jkoenig24
That beeping signifies that the "Self Destruct" sequence has been initiated. You have 10, 9, 8,........... oops, too late.
jkoenig24 is offline   Reply With Quote
Old 09-21-2017, 12:43 PM   #18
It is the CO2 detector. The battery is weak causing it to beep. Disconnect your battery when storing the camper.
2017 Rockwood A213HW
2006 Honda Odessey
sholdeman is offline   Reply With Quote
Old 09-21-2017, 12:51 PM   #19
I let my 1978 nova with no converter warm up the engine with the window open on the other side of the camper (2504s) and it set off the CO alarm ! Jay
Jay2504 is offline   Reply With Quote
Old 09-21-2017, 01:13 PM   #20
Mine did the same thing when I kept it in the garage. Low battery charge caused the beeping. Still miss that popup
sailtrkr is offline   Reply With Quote
