I have a Flagstaff MAC 176 LTD. The brake light/turn signal light is burnt out. What is the replacement bulb and how do I remove the red cover to replace the bulb?
The cover pulls off. Just inspect it closely and you’ll see. The replacement bulb number will be stamped into base of an existing bulb. To remove a bulb, push in slightly and turn then it’ll come out. It’s quite likely that it is bulb 1157 (mine are and it’s a common bulb for this application). The bulbs usually come in two packs so I replaced both on our pop up when one went out. I figured the other was soon to follow.
