10-08-2018, 05:37 PM
Cable wrapped around pully
I have a 2004 Rockwood model 1980 and we just got back from camping and I was trying to raise the roof to clean it out but could raise the roof over an inch and this is what I found when I looked at the cable, how can I fix this easily? I thought either removing the bolts that hold the pulley the frame or loosen the whole pulley bracket and see If that would work. But the cable is under tension right now and I want to do this the safest way possible.
10-08-2018, 05:47 PM
Confused it sounds like you are describing a picture but there is not one attached..
10-08-2018, 05:48 PM
Can you post a pic of it? Sounds like you could chock the roof up and then take the tension off the cable and fix it. But as I said, a pic would help a lot.
Gotta go campin!
10-08-2018, 05:53 PM
Picture wouldn’t here is video
Here is a video to show the cable and how far the top opened
10-08-2018, 05:54 PM
Video isn’t loading now
10-08-2018, 06:09 PM
https://youtu.be/Aj_NJYuqeTA
10-08-2018, 06:33 PM
The video is too short to determine much. is it possible to let it down and remove the tension and disconnect the winch? I had that happen on my enclosed trailer door pully. I was able to backwind the pully and put the cable back on.
10-08-2018, 07:06 PM
New longer video, I tried to lower it but nothing changes.
https://youtu.be/-uAL-q_HUjQ
10-08-2018, 07:13 PM
That makes it much clearer.
Lower the top all the way and then while holding the cable taught by hand (or have someone else do it), wind the winch backward until you can work the cable back onto the drum. then it should work correctly.
Gotta go campin!
10-08-2018, 07:25 PM
I have tried to lower the top but when I try nothing happens, the pulley doesn’t go backwards , it feels like it is already down no friction at all when turning the handle. Is there another way to put it down?
10-09-2018, 08:14 AM
Taking to dealer
I decided to take it to a dealer nearby and have them fix it since I don't want t take any chances with this cable under tension.
Thanks anyway for your help.
10-09-2018, 10:21 AM
Let us know how it turns out. Take a couple of after pics also.
Gotta go campin!
10-09-2018, 10:27 AM
they gave me a ballpark for the repair 300-500 ouch
10-09-2018, 01:04 PM
That seems awful high unless there's a lot more wrong than looks like.
Gotta go campin!
10-09-2018, 01:48 PM
They haven't actually seen it yet (I will drop it off after work) , he said they usually have to replace the cable but I really think if it could unwind I could rewind it and it would be fine. But without seeing it he can't give me a actual price he said he would rather estimate high and come in lower.
10-11-2018, 06:37 PM
I took the popup to Erhardts Trailer upin Des Plaines and they fuxed it for me and even replaced a marker light cover that Inhave been mesning to replace and it was alot cheaper then quoted. $124.00 which I happy with.
Here is a link after the realigned it.
https://youtu.be/CtVyyDOmVMk
10-12-2018, 12:40 PM
Thanks for coming back and letting us know that you got it fixed and that the cost was pleasing. Not often that, that happens.
Oh, the video in that link is before it was repaired!
Gotta go campin!
10-12-2018, 12:48 PM
LOL grabbe dthe wrong video, but its great now
10-12-2018, 03:45 PM
10-12-2018, 03:47 PM
Looks much better now!
Gotta go campin!
