Can someone post wiring pictures of their Flagstaff 176ltd converter?
We just swapped out converters Wfco 8712 and apparently didn't label one thing correctly as we disassembled. Need to know what the red wire(battery positive) connects to on the trailer side of things. Its driving us crazy! The diagram on the WFCO owners manual doesn't help with this side of things.
It is attached to terminal 4 out of the box. I need to know what wire(s) it connects to in the trailer itself. The diagram only shows the converter itself not what they connect to.
I know it is battery positive. But when we connect to the wires we thought it went to, nothing works. Not even Shore Power when switched over to it. Disconnect from that wire and Shore Power works but not 12v. So we know that it is wrong.
There is a black and white wire that that goes to the 12v switch. This wire has a solid white that peels off and gets connected to the lighting pigtail. There is also a solid black wire that runs up to the battery positive side.
This is why I was hoping someone with this camper/converter would chime in. We should've taken pictures... and we thought we labeled everything but apparently not.
Hope this all makes sense.
