Condensation between ceiling and roof on Pop-Up
Hello Everyone! I have a problem that has developed over the last couple of years. I have a 2011 Palomino Pop-Up trailer that has decided to collect water between the roof and the ceiling. The problem began after I started tarping the trailer for winter storage in the Pacific Northwest. I believed it was the roof leaking but the tarp was waterproof. Despite this, I moved the trailer into the garage and I resealed the entire top, including replacement of the corner caps. Once the caulking was cured, I moved the trailer back outdoors and covered with tarp again only to find more moisture leaking through the overhead lights and other ceiling penetrations. There is NO moisture in the cabin area, ONLY between the ceiling and the roof. The water leaks into the cabin from the corners and lights and soaks the curtains and has made puddles on the beds. I've tarped the beds for now. Yesterday, I squeezed the weather seal along the door side and water ran out the end. Has anyone else had such a localized water intrusion during idle storage outdoors? This is madness.
I did purchase a 'breathable' top but the problem persists.
I have not used a de-humidifier or passive heat source to keep the cabin warm during storage and believe this to be the next step, given I have sealed any likely leaks. Your helpful comments will be greatly appreciated.
