Old 08-05-2018, 12:32 PM   #1
Corner Lift System Issue
Hi All,
I could use some assistance as I’m new to the pop up world. I have an 02 Flagstaff 725D with a hand crank cable lift system. I just noticed that the driver side rear corner of the camper won’t lift evenly with the other 3 corners. There’s plenty of play there too when all other corners are fully erected. Is this just an adjustment or more like a cable replacement? If it’s a replacement, is it fairly simple?
Thank you in advance!
Bill
Billy228 is offline   Reply With Quote
Old 08-10-2018, 09:36 AM   #2
I can't completely answer your question in that I don't know about the cables being individually replaceable, or if they are all on 1 single cable. Plus, I doubt it's the cable.
What you might check is the actual surface the post mounts to, in the roof of the PUP. I say this because ours is weak there, very weak, and needs to be repaired / replaced. I noticed our drivers side rear brace has some play, and that's the reason for it.
Might actually see if that's your problem, and not the cable lift system.
Greg, Janelle, Tenley, & Ellis
2019 Palomino Puma QBSS
TV: 2015 Silverado Z71
Other toys: 2007 Rinker Captiva w/Monster tower & rack
GXPWeasel is offline   Reply With Quote
Old 08-24-2018, 07:17 PM   #3
I’ll take a closer look. That one corner is soft from a small leak so we’ll see. Thank you!
lift
