Originally Posted by Jchaney
I purchased a 2008 Rockwood HW276 and it was disclosed that a couple of the interior dome lights have gremlins.
First let me apologize for any grammar or spelling errors. I am posting from my phone.
Troubleshooting to date. Two of the rear most lights work. I can plug the fans in and they work. The fans above the galley and the front bunk do not. No fan power and no lights.
I used my multimeter and verified resistance. .01 on each light.
I then removed the bulbs and tested dc voltage. The bad lights have a voltage anywhere from 6-8 volts. The lights that work I have dc voltage at 11 vdc.
I assume I have a corroded connection or a bad ground somewhere causing the voltage drop.
Where are some common culprits to look for poor grounds? I did note that the voltage was higher at the galley light (8 vdc) than the front bunk light (6vdc)
Lastly the rooftop fan does not work. Not sure if this is related.
Interesting problem. The wires in the roof originate at one of the lifter posts going up the inside of the tent fabric and branch out to the lights and connector sockets (if you have those too). There is a pos. and neg. wire so there really isnt a "common ground" like your car frame. Its all wires all the way on your trailer. I'm at a loss on the voltage drop I am afraid unless its like Christmas lights where each light shares a part of the voltage and are connected in series. That though should be evident because one bulb removed would knock out all downstream from it so they are most likely wired in parallel.
