Originally Posted by bobstepsup
We had that type of an issue with our Palomino TXL Fold-a-Wall.It has poles on the sides for support , not cables as many have. We took care of the problem by using a clothes line . Our Fold-a-Wall always leaned toward the awning side, so we tied the clothes line to a tree on the opposite side to pull the roof back to straight, and then put the awning up with the poles and ropes. Lined the door right up every time. I hope this helps.
Thanks for the reply ! I got it all sorted out last night. I did something similar to what you suggested. First I replaced all the rivets in the plastic clips that good the frame in, they were all very lose which wasn’t helping matters and someone had stacked washers behind one to try and remedy the problem.
I tied a line off the front left corner and pulled a bit of pressure on it and tied it off on a tree. Then I put the frame in and the tighter clips made a big difference, it now held snug against the frame of the camper.
Then I would the top down a little bit to put some slight pressure on top of the door Frame but not enough to slacken the cables.
I let the line go and everything stayed put and is good and solid.
I did find out that the osb at the front right corner is all rotten and that’s probably contributing to the issue as I’m sure there’s some sag there with the steel guide not really having a solid mounting point.
I think some of the problem may have been me expecting everything to fit right together nice and snug. And that is for sure not the case but it’s pretty close with some tinkering. I’m completely new to tent trailers so it’s a bit of a learning curve. Appreciate the replies from everyone.
