Originally Posted by Ssyms
After sliding the door in and nesting the door to latch the bottom, I end up with nearly an McG gap at the top. The pressure from the gap pulled the screws/latches out of the wall. We have already had this repaired once. Which they simply screwed the latches into a different part of the wall. Everything is leveled well, but I’m now left with the Velcro securing the top half of the door. Any resolves?
2021 Forest River Flagstaff Sports Enthusiast Package 206STSE
We have the same model as yourself, albeit it's a 2023, and also had the same issue with the upper door gapping, and the latches pulling out from the pressure.
How we remedied the situation was to remove the Chrome Strip off the top of the door and reverse it so the chrome strip is now flush with the outer wall. That took care of the gapping problem for us. And also, when we go to latch the Chrome Strip to the outer wall, we also pull the roof inward so the strip meets the wall, and then latch. Problem solved. No more undue stress from pressure pulling.
It seems like the Chrome Strips were installed backwards in my opinion.
