Old 06-19-2023, 11:59 AM   #1
Electric winch not operating
I have a 2018 Flagstaff 176LTD and all of a sudden the winch is not working. The battery is new and I opened and closed the camper last week using the winch. I tried removing the circuit breaker from the battery and it still does nothing?
Thoughts?
Thanks,
Charlie
Downeast Draper is offline   Reply With Quote
Old 06-19-2023, 12:17 PM   #2
bikendan's Avatar
Moved thread from the General Community Discussion section to the Tent Camper and Popup section since the OP's questions are specific only to popups and not general questions.
Sent from my SM-G781U using Forest River Forums mobile app
Old 06-19-2023, 12:35 PM   #3
Turns out my drive gear broke off of my winch motor about an hour ago... got a trip planned for Friday. I'll do a little lookin around at my wiring and see if I can give you some tips on what to check.
Project13thirty1 is offline   Reply With Quote
Old 06-19-2023, 12:46 PM   #4
Wench motor broke... and manual operation
First trip planed for Friday in our New to us hw27ks... opened it up to pack today and make some repairs... boom wench drive gear snapped off. Noone within reason has a replacement for me to go get quick. Had to order one straight from the mfg. Does anyone know if they changed the shaft design on these motors? It's a 3/16 shaft between the motor and the gear, no wonder alot of people have them snap off. I've got a friend that's a machinist so I'm gonna see if we can make some "improvements" to the design. If it works out I'll keep the new one as a spare or sell it if we can make the old one work better. I did figure out a way to work these things manually tho so I'll post some pics and a description later when I get a few minutes.
Old 06-19-2023, 06:29 PM   #5
Sorry that was supposed to go in a new thread
Old 06-20-2023, 08:57 AM   #6
Thoughts?
Thanks,
Charlie
Clean the contacts on both sides of the breaker and reconnect. After messing with the switch and checking the wiring on the underside it was simply corrosion on the connector from the wire to the winch at the breaker.
you can test by wiggling/moving that while flipping the switch
flyerdp is offline   Reply With Quote
Old 06-20-2023, 09:01 AM   #7
I will definitely try cleaning the contacts. Thanks!
Old 06-30-2023, 07:41 AM   #8
Hi, i have a rockwood 1940ltd. My winch is not working anymore on up to open, only on down it works. When i flick the switch up i can ear a click sound in the motor but nothing happen's. Anybody have an id on what is the problem????
Patcorb is offline   Reply With Quote
Old 06-30-2023, 08:00 AM   #9
See this post with details on diagnostics including a video on the relay system. That is assuming yours is a newer model popoup
https://www.forestriverforums.com/fo...ml#post2624179
Old 08-01-2023, 01:56 PM   #10
Had this happen to me last year. Turned out to just be a bad switch. New switch and works great.
Bljorgensen82 is offline   Reply With Quote
electric, manual, motor
