Originally Posted by wmtire
The CO detector can have a low voltage warning, that goes off if the battery is getting low.
If you had it sitting for several weeks, and not connected to shore power, then the battery could have gotten low from parasitic drains (The CO detector being one of these drains).
It's possible also when you disconnected the battery, it kind of recharged itself a little.
I'm going to second this answer, and even tie in the speaker issue.
I'm willing to bet that the voltage was low and caused the radio to power off... then power on, then off, then on/off/on/off. This could cause your speaker buzzing as well even on 'off/standby' mode.
Connect it to shore power and see if that fixes things, then get yourself a battery tender so you don't fry that!
