10-26-2017, 06:24 PM
First time boondocking -electricity
Our propane is working, battery is charged but we are getting no electric inside camper. Can't figure out why. Any suggestions? It's a Flagstaff228D pup
10-26-2017, 06:28 PM
12 Volt or 120 Volt?  Youroo!!
10-26-2017, 06:29 PM
No hook up site 12 v battery
10-26-2017, 06:32 PM
We've done full hook up several times with no problems, first time dry camping and we are getting no electric.
10-26-2017, 06:34 PM
Scoundrel
It sounds like your battery cutoff switch is still engaged.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
We just connected battery to jumper cables and truck, no power, connected the 7pin to truck, still no power
10-26-2017, 06:35 PM
You probably running off the converter only then, there should be a small breaker that might have tripped on or around the battery, should have a little black reset bottom, if I understand you correctly.
Coachmen M/H
Concord
2018 / 300 DSC
Where do we find that switch?
10-26-2017, 06:37 PM
You must be plugged into a power pedestal to get your 120 vac power. if you have no 12 vdc power check your battery disconnect. your lights,water pump, ref, and furnace all work off of 12 vdc. the air conditioner and microwave and TV work off of ac.
 2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
10-26-2017, 06:38 PM
You might not have a battery disconnect, the breaker is small maybe 2"x 1" should be on the plus side of the battery cable mounted to the frame or trailer.
Sent from my SM-N920V using Forest River Forums mobile app
Coachmen M/H
Concord
2018 / 300 DSC
10-26-2017, 06:39 PM
Usually under the frame, between the battery and the junction box.
2011 Traverse LT, 3.6L, FWD
10-26-2017, 06:42 PM
Popups don't come with factory disconnect switches.
A previous owner might have added one.
10-26-2017, 06:44 PM
If the OP doesn't have hookups, what would the converter have to do with it?
10-26-2017, 06:46 PM
We bought it brand new in July
10-26-2017, 06:49 PM
Trace the battery wire from where it leaves the battery box, to where it goes underneath the main trailer body past the tongue. Look for a small rectangular box similar to the one in the pic. See the small black button on the end of it, which the location varies per circuit breaker....press this button in and release. This resets the circuit breaker which could be tripped. It happens a lot. You may also have more than one resettable 12 volt circuit breaker there.
If it's tripped, then power is not getting past this point.
You may also have an inline fuse on your main battery cable. See if it is good and/or making connection.
 2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
10-26-2017, 06:53 PM
He just looked, said there's nothing under the like that
10-26-2017, 06:57 PM
There usually is. I would look at the positive battery cable, then follow it to where it connects to something underneath the front of the trailer, and see what that is.
The 12 volt circuit breaker can be of varying styles and doesn't have to look exact to the pic I posted. It is many times attached to the inside of the frame rail.
Anyway you can snap a pic of that area and post it, as that would help?
10-26-2017, 07:00 PM
OK, we have power but faucet won't work. Water pump is on, tank is full but nothing coming out of faucet.
10-26-2017, 07:02 PM
What did you do to get power?
Did you hear the water pump come on?
Thanks wmtire, looks like something else we are going to have to find but he says it's not there
