Old 01-02-2019, 10:14 AM   #41
fkiehner's Avatar
Finally got the furnace fixed. I was originally told that they (OW) ordered a control board for the furnace but I don't believe that was the case. After an hour of trying other stuff they found another defective furnace that they had removed from another popup and they took the control board off that unit and put it in mine. They told me that they tested it and all is working well now. Guess we will find out when we go out next time. Got a 2nd 20lb tank and hose and filter to get along with the Buddy Jr I just purchased so at least I will have some heat if the furnace leaves me sitting again.
fkiehner is offline   Reply With Quote
Old 01-02-2019, 10:37 AM   #42
Denver To Yuma In 90 Days
Is there any reason you can't test it out BEFORE you go out next time?
JohnD10 is offline   Reply With Quote
Old 01-02-2019, 10:43 AM   #43
Agreed... I would have been testing it at the dealer BEFORE I left after repair.
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 01-02-2019, 12:12 PM   #44
rsdata's Avatar
Maybe some driveway camping? Even if only temporarily removed from a storage unit. If it is gonna break then do it know.
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 01-13-2019, 09:38 PM   #45
fkiehner's Avatar
Checked it out and it does, in fact, seem to work. Now the little lever on the thermostat is almost broken off. I can remove the cover to adjust the temp so I may have to figure a work around until I can find my super glue to glue that back on. Always something!
Old 01-16-2019, 01:41 PM   #46
Bob414
Same Problem on NTM 2014 FS 206 LTD
Lights would sometimes work, Heater would cycle once, and not re-light and cycle. The previous owner provide a small auto type battery, 450A, Hooked up a 15A battery charger to that battery no change.
Connected the 7 pin connector to my car, heater came back on and cycled, Light works every time.
Replaced the wimpy battery with a deep cycle/marine battery and was able to run for at least 6 hours, driveway camping and weather stopped the test.
Lesson do not use a wimpy auto battery.
Bob414 is offline   Reply With Quote
Old 02-03-2019, 08:13 PM   #47
If the probe is red hot ,but gas does stay lit sounds like a bad thermo coupler.
Ben
benfox49 is offline   Reply With Quote
first time
