Originally Posted by MohicanJeff
Thanks for the reply. I would assume you used 1" pvc pipe and looks like maybe Velcro to attach the flag? Did you glue the fittings or leave some loose for ease of storage. Any other ideas out there?
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
i used 1 inch pvc and i drilled holes the distance of the flag holes and bought 2.5 loop bolts with nuts on the end for the pvc flag holders. i then used small little snap on clips to hold flag to loop screws hope that helps and no i didnt glue any part of it so it can break down for easy storage. i then took a rebar pounded it in the ground and place flag pole over it for stability
