Flagstaff 206LTD questions
Hello everyone, been lurking here for the past few days finding a lot of useful information on my recently bought 2001 flagstaff 206ltd.
The previous owner didn't really know how to use it so I didn't get much training from him. There is a converter under the diner seat and I didn't find a switch on it to go from 110v to battery mode. The precious owner only used the 110v... Could it be possible that the converter has been replaced with a newer one which has an automatic switch? Also, would it also charge the battery at the same time?
My last question is, what is the required tire pressure? The sticker on the frame faded with the sun and I'm unable to tell the recommended pressure... The max pressure on the tires is 80psi,so I would assume it's something around 50psi..
Thank you!
