Originally Posted by BoulderT4R
Edit: I should have said they found a loose wire on the converter, not inverter.
Anyway, they said they supposedly fixed the issue with the outlets by addressing a loose wire on the converter. I’ve had it at home the past few days plugged into 120v in my garage and today realized the shore power was not charging the battery and as a result the CO detector was beeping. It’s to the point now that the battery is completely dead. The battery does hold a charge when I use a trickle charger but the 120v plug in does not seem to be reaching the battery. So if they fixed the outlet issue it seems to have resulted in a new issue.
Does anyone know where the converter is in a Flagstaff 207SE? I may try and see what then fixed and maybe undo it, instead of making another hour drive to the service department.
The converter in a PUP is generally under a dinette seat or sofa. It is almost always facing the center aisle at the same location as your power cord comes into the camper. It has a brown or black cover that flips down to show you the circuit breaker and fuse panels.
Converters in a PUP are combination electrical panels and converters, the converter is located behind the panel, usually behind the fuses.
Your service dept is letting you down more than the camper - not an unusual experience, unfortunately. A loose wire on the converter has NOTHING to do with the outlets not getting power. In this case, if you don't know enough about electrical to take care of it yourself, you need to find an RV tech that does understand electrical.
Owning an RV is like owning a house. If you can't take care of the systems yourself, you have to find somebody who can. Not everybody who calls himself a home handyman is. Not every RV service dept knows how to service an RV, and this is especially true with small campers and pop-ups. A dealer who specializes in pop-ups, or an independent RV repair will give much better service.
Unfortunately, the wiring in most new pop-ups is a rush job on the assembly line. If you lift up the seat cover over your converter, you will see a rat's nest of wiring behind it (along with lots of sawdust). Surprisingly, most of it actually functions despite the poor quality of the workmanship. When I replaced my converter in my A-frame, I spent a couple of hours putting in bus bars to get rid of the rat's nest of crimp on wire nuts.
I suspect your entire AC system is down, which takes the converter out with it. The simple test for AC is whether the microwave works or not.
In the meantime, you need to have your battery tested, and keep it charged with an independent charger. When you install a cut-off switch, then you can leave the fully charged battery sit unattended for a couple of months.
hope this helps
Fred W
2019 Flagstaff T21TBHW A-frame
