Old 07-16-2017, 08:44 AM   #1
Foam still coming out of faucet
I have a 2017 2280BHESP and I've filled the tank a couple times and foam is still coming out of the faucet. How many fill ups does it take to remove all the factory winterization in the tank?
Dumouc56 is offline   Reply With Quote
Old 07-16-2017, 08:57 AM   #2
If you Sanitized the FW tank and drained it there should be Very little water in the tank,put water in tank,put element in filter,hook up to City water.run City water through ALL Water systems,then turn OFF city water and run Pump through A outlet! Should run Clear now! Youroo!!
Old 07-16-2017, 08:59 AM   #3
Crusadernoob's Avatar
Drain the low points, I had a problem with antifreeze, it would pull out of the drain line. Never happened again after I learned that.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 2
Crusadernoob is offline   Reply With Quote
Old 07-16-2017, 09:03 AM   #4
Carknocker Family
Ida Ratherbe Camping's Avatar
Did you drain fw tank before filling. If not, drain it. Then start fresh, also drain water heater.
After winterizing in spring, I flush my lines with fresh water and a little bit of bleach before putting water heater in loop. Bypass heater before ever winterizing and the antifreeze will never be in there.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 07-16-2017, 09:05 AM   #5
Yes the LPDs are a "Dead End" of the water system same with the OS Shower,need to Open/Flush Everything! Youroo!!
Old 07-16-2017, 09:10 AM   #6
Thank you. The only thing I didn't do was sanitize it or add the filter. Otherwise I did everything else. By sanitizing is there a recommended solution to use(ie bleach)
Old 07-16-2017, 09:14 AM   #7
Yes there is a Procedure do a Search at Top and there is all the Info for Mixture and "How To"! Youroo!!
Old 07-16-2017, 09:17 AM   #8
I dont believe I did empty it before filling it up. Only thing I did was open up the bypass valve(which I wish they had done it differently with either Velcro holding the door in place instead of screws) and filled it up. Now to drain the hw heater is remove the plug by the ingnitor correct?
Old 07-16-2017, 09:37 AM   #9
Yep! Drain & Flush Everything! Youroo!!
Old 07-16-2017, 09:57 AM   #10
Carknocker Family
X2
Just start over, flush and sanitize and you should be good to go.
2017 Ram 2500
2014 Salem 32BHDS
Old 07-16-2017, 10:53 AM   #11
Thanks for all the replies. Will do that once I get the chance after getting serviced this week!
Old 07-16-2017, 12:51 PM   #12
Isn this website just GREAT!��
twoclaws is offline   Reply With Quote
Old 07-16-2017, 12:58 PM   #13
Most definitely.
Old 07-16-2017, 01:05 PM   #14
GC !! drain fresh tank and refill. Hook hose to city water and run for 5 minutes..Hot/Cold open. Tank clean, lines clean, HWH flushed. Depending on flow rate 5 minutes puts around 12 gals thru my HWH, the equivalent of flushing twice.
TheWolfPaq82 is offline   Reply With Quote
Old 07-16-2017, 08:53 PM   #15
Ham Call N8SAC
Maxwell D Pratt's Avatar
The manufacture recommends 1 oz. per. 10 gal. Of water. If you have a 30 gal. Tank would be 3 ozs. of 5% bleach. I do this every spring when getting camper ready for the camping season. And you are supposed to drain tank after each camping trip. I just read this today in my manuels .
Maxwell D Pratt is offline   Reply With Quote
Old 07-16-2017, 09:10 PM   #16
Flybob's Avatar
I think you are referring to fresh water tank. There is really no winterization needed for the FW tank. Just drain it. If you believe the dealer put antifreeze in the FW tank, It will take a while to get it out, You will just have to fill. and drain FW drain until it is all out. You never want to put antifreeze in the FW tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-16-2017, 11:26 PM   #17
bikendan's Avatar
I was also wondering why the OP put AF into the FW tank.
Not necessary and gives the tank an odd taste.
Old 07-16-2017, 11:34 PM   #18
I didn't read where the OP put AF in the Tank,he was asking about F/R MFG putting winterization in the System! Youroo!!
Old 07-17-2017, 05:24 PM   #19
vasnipe's Avatar
Hot water heater
When you sanitize the water heater along with the system be sure to drain and flush it as well. I forgot that step a year ago or so and came out of the shower smelling like I'd been in over-chlorinated swimming pool. Good thing my hair is almost all grey, I could only imagine if Mama-san had gotten that water instead of me...
Lesson learned.
Hope this helps.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 07-18-2017, 12:35 PM   #20
Remember that bleach does not kill 100% on contact. Pour it in and take a drive around the block to swish it around. Three minutes is minimum. Five minutes kills it all.
Raise the side opposite of the water heater a bit when you pull the anode do make sure the tank drains. I put a flexible tank wand deep in there to flush it. Lots of calcium and crud pours out.
carlsbad is offline   Reply With Quote
faucet
