Old 09-21-2021, 03:38 PM   #1
Cowboy6201's Avatar
Found Circuit board laying next the water heater in my HW 296
Anybody know where this attaches too.
I found it just laying on the floor when I opened up the panel to turn on the water lines, I was getting ready to go campeing in August, but can't seem to find where it should be mountedClick image for larger version
2017 Ford Explorer Sport3.5L Twin Turbo
2018 Rockwood Premier HW296
Cowboy6201
Cowboy6201 is offline   Reply With Quote
Old 09-21-2021, 03:54 PM   #2
B and B's Avatar
Hello
That is for the water heater. The ignition for the propane, sensor controls etc. They usually just hang it on the back with a tywrap. Someone forgot to screw it to the wall.
Old 09-21-2021, 04:03 PM   #3
wmtire's Avatar
That is the module board for the 12 volt dc heating(propane) mode of the water heater. Sometimes they are just held on with double sided tape to the foam on the tank. I almost think i can see this tape at the end of for tank but the picture cuts off.
Also the valves to the tank both look closed, the cold water inlet as well as the crossover valve. I can barely just see the hot water outlet valve but it's also cut off in your pic. Did you do that on purpose with the valve positions.?
2011 Flagstaff 831 RLBSS
Sometimes, I sit and wonder about what actually happened to all those people I gave directions to.
Old 09-21-2021, 07:42 PM   #4
Cowboy6201's Avatar
I was getting ready to open them.
Cowboy6201
Old 09-21-2021, 07:50 PM   #5
wmtire's Avatar
Open which ones? You will normally only open the cold water inlet and hot water outlet valves. The crossover valve is used for winterization purposes if you put antifreeze in the lines. That valve needs to stay closed if you are using the water heater while camping.
This thread may help:
https://www.forestriverforums.com/fo...st-103381.html
Old 09-22-2021, 01:25 PM   #6
Another quality job by how fast can I make this trailer. Things that come loose (3 cents worth of glue), fail (cheap Chinese), fall off (nails in aluminum) and all the other uber annoying things that get fixed after every trip.
RussPastuch is offline   Reply With Quote
Old 09-22-2021, 01:56 PM   #7
Ding ding ding! Winner winner chicken.....
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
Old 09-22-2021, 02:14 PM   #8
D W
D W's Avatar
Hmmm, 2018 model, and not noticed until now? Lots of possibilities here.
2016 Salem 27RKSS
D W is offline   Reply With Quote
heater, water, water heater
