Old 08-14-2017, 02:54 PM   #1
Freedom with power winch not lifting
Went camping past weekend and top would not raise to proper height. After several people trying to help, the top now only raises to about 6 inches. Is there a way to reset and/or adjust without taking to shop?
Blkdog lady is offline   Reply With Quote
Old 08-14-2017, 03:54 PM   #2
Amartin453's Avatar
I have a 2016 Rockwood Premier and the winch needed to be replaced within the first year, luckily it was under warranty. Now the switch is acting up sometimes it works and sometimes it doesn't. On our last trip the winch raised the roof but would not lower it, (I had to manually crank it down using my drill). I'm going to try to replace the switch. Also, you may want to check the "limit switch" it may just need to be adjusted.
Amartin453 is offline   Reply With Quote
freedom, lift, power
