We have a 2017 MAC 208. This past year we have had to use the furnace. It has worked pretty well when needed.
However, on the nights that we don't need and we have set the thermostat to off we have noticed that if drops into the 40s the furnace will kick on unexpectantly. My first through is that the thermostat might be problematic, but it is working when needed.
However, on the nights that we don't need and we have set the thermostat to off we have noticed that if drops into the 40s the furnace will kick on unexpectantly. b
Has anybody run into a similar issue?
Thanks!
Shawn
Posts by Dalford and 5Picker have given you the correct answer.
Be aware that these old-style mechanical thermostats are very robust. Nothing ever goes wrong with them. It's the new electronic thermostats that can cause problems.
Larry
