Part Timer Door Problem
Part Timer, I have a Rockwood 1950 Pop-Up. You need to raise the top a bit more and the clips will go over the top of the door. I sometimes have to use my hand crank to get the top a bit higher. Yes, those slots are too small. And as others have said, level the camper using blocks under the wheels (for left to right), and the tongue crank (front to back) before putting the door in place. This will make fitting the door much easier. Hope this helps.
2020 Cherokee Wolf Pup 16FQ
2018 Honda Pilot AWD
