That should not be happening if I were you I would take soap solution and check all the fittings and tighten if required. It may also be that the main gas valve is leaking slightly after shutting down agin soap solution on the nozzle should indicate if this is happening. let the forum know what you find
Retired Navy
2016 Flagstaff 26 FKWS
