Closed Thread
Old 04-10-2019, 02:03 AM   #41
Originally Posted by Qball View Post
Yes my water filter is exactly above all the electrical fuses and other electrical as well
With a pc of almost plywood less that 1/8” thick. Not water proof what’s so ever Lol
Just blows me away by who thinks of this stuff?
Mine isn't in the electric area luckily. It's under the couch with the furnace and water pump, just horribly placed over the water lines.
brwarrior is offline
Old 04-10-2019, 02:04 AM   #42
Originally Posted by rockfordroo View Post
Wrap a plastic bag around it before you unscrew it.
If it's an FR1/KW1, you might want to remove it before it cracks and floods your rig. Lots of threads here reporting this problem. A 67 cent coupler from Home Depot fixes the problem.
Attachment 201344
Attachment 201345
Attachment 201346
Thanks for the tip on the bag. Obviously I never thought of that.
Old 04-15-2019, 06:20 PM   #43
Try the faucet screens not plugged
dwan is offline
Old 04-15-2019, 07:20 PM   #44
Hot water tank
Some tanks have check valve on hot line it s a brass pc that screws in tank
rickmack is offline
Old 04-15-2019, 09:11 PM   #45
Is the coupler you used specifically made for pex? I hate that filter. We have to get our son to remove it as it takes a contortionist. I appreciate your adding pictures so we can picture exactly what's needed.
Desertsquid is offline
Old 04-15-2019, 09:36 PM   #46
Did you try opening the out side drain for a few seconds? Also do you have a winterize valve that is set to winterize it should be turned to operate.
Gonzo is offline
Old 04-16-2019, 09:52 AM   #47
I'm s fulltimer. After using my HWH for 4 years one morning hot water would not come out. I found a check valve on the hot water output side that had frozened shut. It's used to keep antifreeze from fill-in tank when winterizing. I pull the check valve and all was good. Suggest you first open the HWH pressure relief valve and see if water comes out. If so then your input is fine it may be this check valve on output. If water does not come out of pressure relief valve then water is not getting to the tank. Hope this helps.
txcolumbo is offline
Old 04-16-2019, 10:02 AM   #48
Solution was found in post #30.
It was a kinked line.
Iwritecode is offline
Closed Thread
hot water, tank, water, water tank
