Originally Posted by Scrapper
When drilling through oriented strand board with a spade bit it is quite hard to make a clean hole unless you drill part way through from one side then finish from the other side or use a heavy tape on the surfaces to control the splintering.
Roger that, but how much more work would it have taken to put some rubber gaskets in there and sealed those holes up and insulated the pex and wires from the OSB?
That's what I am going to do tomorrow. Raining right now.
