I ended up replacing the whole thing when I had a leak at the hot post running on to the counter. I replaced both the valve O rings with like size but no good :/
Below is what I got from Lowes.
I will say the only way I was able to use the veg sprayer because of the fact that the bunk stopped short of the sink and didn't go over it otherwise it would break it even if I pulled it out and left handle in the sink.
The only other difference is when I unscrew the faucet there is a small white washer in the hole that could come out. I push a piece of paper tower in the hole to keep it in place during travel. Its basically a screen. I works find without but I will keep it as long as I can.
