Old 06-21-2021, 09:53 PM   #1
HW277 no hot water pressure
Hi all. Picked my 2020 up Saturday and at a site now and canít get any hot water out of any faucet/shower. Hot water tank has hot water in it coming from the relief valve and Iíve tried the 3 valves near the hot water tank (including the cross over valve).
Any other valve that could keep the hot water from flowing?
Chad
biggie240 is offline   Reply With Quote
Old 06-21-2021, 10:08 PM   #2
wmtire's Avatar
Originally Posted by biggie240 View Post
Hi all. Picked my 2020 up Saturday and at a site now and can’t get any hot water out of any faucet/shower. Hot water tank has hot water in it coming from the relief valve and I’ve tried the 3 valves near the hot water tank (including the cross over valve).
Chad
Can you post pic of your valves behind the water heater?
This thread may help:
https://www.forestriverforums.com/fo...st-103381.html
2011 Flagstaff 831 RLBSS
Life is about changing perspectives and priorities: I used to worry if one of my hairs was out of place, now I don't care if they both are.
Old 06-21-2021, 10:20 PM   #3
Trying to figure out how to upload the pic. See if this works. Iíve tried all ways of the valves I can think of.
Old 06-21-2021, 10:29 PM   #4
wmtire's Avatar
Trying to figure out how to upload the pic. See if this works. I’ve tried all ways of the valves I can think of.
The valves in your pic look to be correctly aligned for normal usage. Sometimes though, the valve can fail internally and you cannot see it (ie, the handle turns outside the fitting but the valve doesn't turn inside the fitting)
Does the hot water valve handle (red water line at very top of heater) seem loose/different when you turn it vs the other valves?
Old 06-21-2021, 10:41 PM   #5
None seem different and feels like hot water in the line after the valve.
2020 Rockwood HW277
2012 Infiniti QX56
Old 06-21-2021, 11:20 PM   #6
Virginian's Avatar
I believe I would try turning off the water heater and draining it, then open the low point drains with faucets open. It sounds like the hot water line may be clogged if you can feel hot water in the line after the bypass valves, but it's not making it to the faucets.
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
Virginian is offline   Reply With Quote
Old 06-21-2021, 11:55 PM   #7
Iíll try draining tomorrow then. Was going to call a local FR dealer tomorrow as well possibly to see if they had any idea.
Old 06-22-2021, 05:15 AM   #8
jwh4984's Avatar
Check the hoses I have the same model they get kinked easily
jwh4984 is offline   Reply With Quote
Old 06-22-2021, 06:51 AM   #9
Are you getting any water flow out of the hot side? If not then I suspect the hot side check valve is stuck or installed backward.
Gotta go campin!
Old 06-22-2021, 06:57 AM   #10
Would assume it would be stuck and not backwards since it was owned previously.
I didn’t see any kinks but will inspect again.
2020 Rockwood HW277
2012 Infiniti QX56
Old 06-22-2021, 08:21 AM   #11
fonzie's Avatar
If it was winterized and the low point drain was used to empty the water heater, then there is a possibility that debris from water heater got into the cold line. When it was time to dewinterized, water from the cold line with debris got into the hot water line through the by-pass plugging all hot water faucets. Take one hot water faucet apart and see it is plug at the valve seat.
Fonzie
Old 06-25-2021, 02:13 PM   #12
fonzie's Avatar
Any update on this issue?
Fonzie
Old 06-25-2021, 03:50 PM   #13
Started getting a little better but still slows down. Just got home today so will try draining everything in the next few days.
2020 Rockwood HW277
2012 Infiniti QX56
Old 06-25-2021, 04:52 PM   #14
Trailer Park Supervisor
NJKris's Avatar
These heaters generate a lot of mineral sediment. I wouldn't be surprised if some got stirred up filling the heater and somehow clogged a line/valve. I always use the pressure release valve to let air out of hot water heater as I fill it for this reason, then try to wait a bit for things to settle before attempting to run hot water.
When you drain everything, take off any faucet aerators before blasting system with compressed air or water, before opening faucets to clear lines/check flow.
NJKris is online now   Reply With Quote
Old 07-05-2021, 06:15 PM   #15
Believe this was finally figured out. There was a kink just below the floor coming out of the hot water heater. After draining and trying to get air through the system without success I tried taking the line off just outside the water heater and pushing air. Nothing until I pulled on the line a little and noticed some got through. Pulled line more and noticed the kink.
2020 Rockwood HW277
2012 Infiniti QX56
Old 07-05-2021, 08:31 PM   #16
NJKris's Avatar
Glad you discovered culprit. when I picked up my camper, I was lucky enough to notice there was a kink in my black tank flush hose. Plant did not leave enough slack to make radius without kinking. Camping World fixed it by putting a couple hose clamps on kink to keep it straight. I was a little dubious, but it's still working.
hot water, pressure, water
