Old 06-06-2018, 07:03 PM   #1
CarpeDiem's Avatar
Idea for mattress pad
We have only used our pop up one time since we bought it. I put the 3” pad on the bed that we had from our last camper. It made that side very hard to close, so I wonder if anyone has any ideas for a way to make the bed a little more comfortable without having to remove and store the pad each time. One thought I had was to cut those rubber interlocking pads that are used for gym flooring.
2018 Rockwood Premier 2516G
2014 Nissan Titan
“Always do what’s right; this will gratify some and astonish the rest” – Albert Einstein
CarpeDiem is offline   Reply With Quote
Old 06-06-2018, 08:28 PM   #2
Tuefel Hunden's Avatar
I'm curious to know what others are using myself. We just purchased our pup a couple of weeks ago and after taking it out last weekend for the first time, I found out just how uncomfortable those mattresses are.
2018 Flagstaff HW27SC
Tuefel Hunden is offline   Reply With Quote
Old 06-06-2018, 08:45 PM   #3
Gold Tee Box
Teetime's Avatar
We have a full queen size mattress in our TT, and ordered the "My Pillow" mattress pad. It's a couple inches thick and really makes a difference, sure beats some foam pad.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
60+ campgrounds/400+ nights, 20K+ Miles towing since 2015
Teetime is offline   Reply With Quote
Old 06-06-2018, 08:53 PM   #4
jwh4984's Avatar
Someone here commented about using a air mattress we tried it and my wife loved it
jwh4984 is offline   Reply With Quote
Old 06-06-2018, 09:12 PM   #5
Thanks Teetime, though I'm not sure a full size mattress would work for us with popups.
Old 06-06-2018, 10:12 PM   #6
bikendan's Avatar
This thread is in the Tent Camper/Popup section of the Forum. The OP owns a popup.
A regular mattress won't work, ESPECIALLY with a topper on it.
Old 06-07-2018, 12:32 PM   #7
Following to see what others have come up with . We put a 3 “ memory foam in our pleasureway which was super comfy but to heavy and awkward too store. Might have to try an air mattress .
Has anyone used the backpacking mattresses they roll up quite compact , so that may be an option
dwreefs is offline   Reply With Quote
Old 06-07-2018, 01:21 PM   #8
If you read the response it states that a 2" My Pillow topper was used on top of the mattress. The suggestion was to use this topper instead of foam.
Not to buy a new mattress.
Mark Duerst
Raleigh NC
2019 Wildwood Xlite 171rbxl
2018 JGC Limited 4x4 w/tow
MarkDNC is offline   Reply With Quote
Old 06-07-2018, 01:40 PM   #9
CampingGator's Avatar
When we had a pop-up we used an egg-crate mattress topper from a big box store. The topper was inexpensive and pretty comfortable. We had no problems when storing the bunk ends.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is offline   Reply With Quote
Old 06-07-2018, 03:23 PM   #10
The Newsoms's Avatar
We have a pop up camper that we pull with our motorcycle. We replaced the mattress with a memory foam topper and it sleeps fine over bare plywood. Way better than what came with the camper! Folds up fine too.
The Newsoms is offline   Reply With Quote
Old 06-07-2018, 03:28 PM   #11
Years ago when we were still in our pop up we removed the original mattress and put a single height queen air mattress on both beds. We would fill them up with a batterie operated air compressor which only took a couple of minutes as we were installing the doors and getting the rest of the camper buttoned up. Worked great but in the mountains the air in the bed was cold and my wife froze so we ended up putting an un-zipped spread out old-school rectangular sleeping bag over the mattress as a cover which helped to prevent the cold air to get my wife. They now have much more comfortable air mattresses so that will be a big help.
Airborne is offline   Reply With Quote
Old 06-07-2018, 06:13 PM   #12
Tiguan Tow r's Avatar
We used the interlocking foam 2'x2' squares under the mattresses and put egg crate foam on top. It made an significant improvement for sleeping and did not affect the ease when closing the sliding beds.
Tiguan Tow r is offline   Reply With Quote
Old 06-08-2018, 08:21 AM   #13
we didn't have any issues. we also have a plastic mattress cover atop the original bed. Figured if it was raining during camper take down it would at least keep the mattress dry
it was very nice to have heated mattress which then warms the air mattress (we do use sheets on the air mattress). Put the fitted sheet over the air mattress before adding air... otherwise it is a pain to get the sheet on at the far corners!
I believe this is the model we have
https://www.amazon.com/ALPS-Mountain...+green+camping
geologist1 is offline   Reply With Quote
Old 06-10-2018, 08:19 PM   #14
Just got our PUP, and my wife looked around and found this,, https://www.amazon.com/gp/product/B0...RIP35NG5Q&th=1
made a big improvement and being only 2" lets us close the camper up.
TimothyG is offline   Reply With Quote
Old 06-11-2018, 06:05 AM   #15
CarpeDiem's Avatar
Thanks for all the ideas. Sounds like we could have a garage full of mattresses/toppers before we discover the right one for us.
Of course, I suspect like most of you, we have five plastic bins full of stuff we used in one camper but don’t need for this one.
2014 Nissan Titan
