Old 08-14-2022, 01:54 PM   #1
inflatable ramps to level tires
Is there such a ramp that you drive onto, then inflate with an air compressor, that will level the PUP?
Mandy & Chris
2022 Rockwood HW277
2011 Dodge Durango Hemi Crew
CFNeumann is offline   Reply With Quote
Old 08-14-2022, 02:43 PM   #2
Good idea, but I've never heard of one.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-14-2022, 02:48 PM   #3
I used this when I had a pop-up, worked well without air.
https://www.amazon.com/BAL-28050-Lig.../dp/B000BH5MAA
latner is online now   Reply With Quote
Old 08-14-2022, 03:17 PM   #4
Who Dares, Wins
doc73's Avatar
Actually a pretty interesting idea. We used air bags inhte fire service for heavy lifts,also used them off road to lift keeps when they were stuck. Used a normal air compressor for the jeep ones.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 08-14-2022, 03:51 PM   #5
bikendan's Avatar
Years ago, there was a small company that made air bags levelers out of fire hose. Forgot what happened but they ended up going out of business.
Problem is that they work with tandem axle trailers and not so much with single axle trailers. The BAL leveler is the way to go because it's a lleveler and a wheel chock. An airbag can't work as a wheel chock.
If you do a search on Google, you can find some DIY instructions on how to make your own. But I don't recommend them for single axle trailers because you can't chock the wheel that's lifted. With tandem axle trailers, you can put a x-chock between the two tires.
ram, ramp, tire, tires
